Ford 3000 pto quit
   / Ford 3000 pto quit #1
kurtwellnitz
Ford 3000
I have a Ford 3000 tractor and the PTO quit. The spline will still spin but not engage. Shortly after, the three point lift arms quit. I have been told that it probably is a clogged filter but dont know location or how to replace. Thanks for any help.
   / Ford 3000 pto quit #3
Welcome to TBN.
It would be a good idea to move this tread to the New Holland section for more input.
I don't understand what you mean not engaging. When you move the PTO lever and release the clutch (with implement hooked up) what happens?
   / Ford 3000 pto quit #4
Hey Kurt! WELCOME to TractorByNet.com! :)
I have moved your thread to the New Holland Owning/Operating Forum. You'll get a better response there. ;)
   / Ford 3000 pto quit #5
Check the to see if there's enough fluid in the rear end. That's where I'd start.
   / Ford 3000 pto quit #6
fluid as nothing to do with the pto if it is not engaging u should look at the shaft and the splines and it and the sliding collar inside the read end
   / Ford 3000 pto quit #7
what trans does this tractor have?
soundguy
   / Ford 3000 pto quit #8
fluid -DOES- matter.. if it is an SOS tractor with independent pto and hyd clutch pack...
we need to know more info...
soundguy
   / Ford 3000 pto quit #9
soundguy
if if was a fifth we would all be drunk but yea need to know what trans is in it
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2022 JLG R3246 ELECTRIC SCISSOR LIFT (A51247)
2022 JLG R3246...
JOHN DEERE LOT IDENTIFIER 154 (A53084)
JOHN DEERE LOT...
2020 JOHN DEERE 8R 250 LOT IDENTIFIER 172 (A53084)
2020 JOHN DEERE 8R...
2001 Nissan Frontier Crew Cab Pickup Truck (A51692)
2001 Nissan...
2016 John Deere 5055E 55HP Utility Tractor (A52377)
2016 John Deere...
