Backhoe thoughts?
   / Backhoe thoughts? #1
smalltown
Gold Member
Western Maine
2011, JD 2520
I already ordered my 2520 and would have liked to have ordered a #46 backhoe. I had heard about the new 270 backhoe that apparently allows the mowing deck to remain in place, (I would remove the deck), but more importantly allows the deck hardware to remain in place. So I was waiting like a few others to look at the 270.
I have just gotten wind of a 3 year old #46 Backhoe on supposidly in great shape for $3,500 that was removed from a 2520. The best price I have seen so far for the #46 is $6,500 with power beyond included. I would need a power beyond for ~$500 and the bracket to onstall on the rear end. If I have it right the #46 runs about If it's true I think it might be something I should no pass up?
It's almost like my wanting to look at the new 1026R that still hasn't arrived.
I had aslo wondered if JD would discount the #46 backhoes to move them just before the new 270 arrived?
   / Backhoe thoughts? #2
$3500 is a great price, and the PB kit should be about $300. Go for it.
   / Backhoe thoughts?
Thanks Kennyd I was thinking for the little inconvenience that the install takes with removing the mower hardware and 3PH the savings were worth it.
I just called the seller and in a few hours I will take a look at it. He told me on the phone it's 3 years old, in good shape and used about 30 hours.
P.S. I know you know your JD stuff thanks!
   / Backhoe thoughts? #4
I would take a look at the backhoe and preferably operate it also. Sounds pretty cheap.
   / Backhoe thoughts?
Ok not being Backhoe knowledgeable here is what I found out in my own words!
It looked like it was in good shape to my eyes (always a good sign to me), and was equipped with the optional 13" bucket
If you look close you can see surface rust on the fittings where the hydro hoses attatch to the cylinders, and also at the end where each cylinder attaches to the main setion of the b
Backhoe.
All the pistons were without any rust, but clean and shiny, and according to the owner do not leak any fluid.
I asked to see it operate and the owner backed his tractor up to the backhoe without attaching it to the tractor just connecting the hydro hoses, and demonstrated all the Backhoe boom movements up and down left and right followed by moving the bucket. All the movements were smooth yet responsive. His tractor was not at a fast idle.
The seat is not in the picture. The owner had removed it as it interfered with his Curtis cab. He showed me the seat and all the attaching hardware that are in as new condition. He also had the safety plackard and the instruction manual.
It appears that those spots where the surface rust had formed must have originally been unpainted metal as all the pistons seemed to have it in exactly the same area. on the closed end of the cylinders.
I was thinking that some PB blaster might help me clean up those spots along with a tiny buffing wheel on a dremel followed by some fresh primer/paint.
It did not appear to have been worked to death, but unfortunately left outside hence the surface rust.
So now it's just a matter of arranging help to transpost the unit.
Which begs another very important question just how would you lift this thing onto a trailer. The seller offered to lift if using his 2520.
I believe the backhoe is 900lbs all assembled, and the 2520 can lift 1031lbs to 59" at pivot pin. I hope that means we can lift it onto low car hauler.
Not sure yet where to even hook onto the backhoe or even if we should try to dissemble some parts before loading.
Anyway It has a 13" bucket and more importantly the 2520 sub frame for my 2520. The only thing I need other than ordering the power beyond is the bracket that needs to be changed out on the rear of my yet to arrive 2520. I'll check with the dealer tomorrow AM.
I offered and he accepted $3,200. I think I made a good purchase.
   / Backhoe thoughts? #6
That I will disagree with.......
You made a GREAT purchase and a fabulous deal.:thumbsup:
   / Backhoe thoughts? #7
wow...you did great!!! ...and with as little paint that is missing from the bucket, i would be surprised if it had more than 3 hours use, much less 30. Glad I saw these pics tho...I will not let mine set outside like that!
   / Backhoe thoughts? #8
just curious why didn't u see if you could get the power beyond kit and the bracket off of his tractor or are they used for something else
i dont know just trying to learn
   / Backhoe thoughts? #9
I also think you did VERY well. I often wonder why I don't come across deals like this. Drop the unit off to the dealer and have them put in on for you.
More importantly don't forget to get the loader arm brackets from the guy that are used to attach the front of the backhoe sub-frame to the tractor and also the two large front pins, they ain't cheap...I know.
   / Backhoe thoughts?
Thanks guys. Looking forward to cleanig it up and using it.
whodat526 the power beyond kit would be a chore to take off. As I understand it most people sell the tractor and backhoe together so I feel fortunate finding a used Backhoe with the correct mount for the 2520. There are other uses for the power beyond kit for the current owner.
Gizmo yes the seller is going to remove the brackets from his tractor. I'll let the the dealer install the power beyond kit, but from what I read it shouldn't be too much off a bear to install the Backhoe myself. My biggest problem will be off loading from the trailer without a tractor loader as my 2520 hasn't arrived yet.
Somehow I'll get it done and take a lot of pictures so I will know how to put the parts/pieces back together (especially the 3PH and mower hangers). At least I know there are smart people here with answers if I have any issues. Tha's what I love about this forum :thumbsup:
JOHN DEERE Z920M LOT NUMBER 238 (A53084)
JOHN DEERE Z920M...
UNUSED JCT 2 PRONG BALE SPEAR (A51248)
UNUSED JCT 2 PRONG...
2023 LMC M40018 LOT NUMBER 176 (A53084)
2023 LMC M40018...
NEW Wolverine Skid Steer Bucket Forks (A53002)
NEW Wolverine Skid...
Freeman Bros 200 Gallon Fuel Tank (A51573)
Freeman Bros 200...
(4) Drums of Mixed Fabric Softener/Detergent (A51573)
(4) Drums of Mixed...
