Gas cans
   / Gas cans #51
I agree.. I'd rather have a 35$ all metal one.. heavy at that.. not flimsy, vs a 10$ plastic one that will die within 6- ys just from ambient uv exposure.
keep paint on the metal one and out of water, and it will last multi-decades..
soundguy
   / Gas cans #53
Guys, I know good quality costs money but get one of these, you will love the can even 20 years from now.
They are from 75/100 bucks, depending in where you by for a 5 gallon.
Justrite Uno ® Safety Cans are 100% tested to guarantee leakproof construction
Blue = Kerosene; Green = Oils; Red = Gasoline; Yellow = Diesel
■Constructed entirely of steel for durability with leaktight, self-closing lid
■Finger-squeeze trigger keeps you in control of liquid flow
■Internal dual-density flame arrester
■Automatic venting between 3 and 5 psig
■USA made
Constructed entirely of steel, these safety cans feature a finger-squeeze trigger that keeps you in control of liquid flow and helps avoid those dangerous spillovers. In addition to meeting your ease-of-use needs, UNO's built-in safety features include an internal dual-density flame arrester to dissipate heat and prevent flashback ignition; leaktight, self-closing lid; automatic venting between 3 and 5 psig to guard against pressure buildup at elevated temperatures and potential explosion; and, every can is 100% tested to guarantee leakproof construction. The flexible metal hose provides a grounding path to prevent static sparks when a grounding wire is used. Can comes in four different colors: red designates gasoline, blue for kerosene, yellow for diesel and green for oils. 1" diameter nozzle. Five-gallon capacity. USA made. Specify color from the selection box above.
   / Gas cans #54
Justrite Uno ョ Safety Cans are 100% tested to guarantee leakproof construction
I would hope that any gas can would guarantee leakproof construction, lol.
All kidding aside both the Eagle and the Justrite cans are nice. I just wish they would put a rubber or plastic edge in the seam at the bottom of the tank. The last one I had eventually rusted after the paint and galvy wore off from sliding around and being stored on cement.
   / Gas cans #55
The 5 gallon Jerry cans are available at most auctions, estate and farm, I get them for 1 to 2 bucks each, you would be surprised at what treasures can be found for little $$, just takes a little time to look thru the stuff.
   / Gas cans #56
kinda like finding gems in the rough at flea markets. I got 2-3 FULL as I could carry arm loads of tools a few weeks ago for 55$ at a flea market ...
soundguy
   / Gas cans #57
We have got a steel Eagle can that someone gave us. Great can second only to an older plastic one we have. The reason I like the plastic one is, is that it is lighter, not as awkward and I just like how it works. These two cans are the only ones which have held up over the years with no leaks. We tried many different cans, even those Jerry cans (it had a flexible plastic spout so it may have been a cheap one,not sure).
Those no-spill ones I wouldn't take the time to throw off a cliff.... well , that may be a little exaggeration but I don't like how they work or how slow they pour or that you have to push this little plastic thingy to get gas out.
EDIT: After looking around, it appears it was a decent can with a cheap nozzle. I'm not sure if we still have it but it appears that you can get better metal nozzles
   / Gas cans #58
Of all the "new style" cans, i like these made by Sceptre:
They have pretty decent balance. I THINK they are a Euro design adapted for NA. Also available with flow control nozzle where you have to hook it on the lip of the tank and push to flow.
The metal cans are sweet. Used them industrially for solvents. Not sure if they are cost effective for fuel though.
   / Gas cans #59
I have that exact can; hate it. Less than a year old, the CARB spout jams up, so you have to just take the nozzle off and pour straight out of the jug and hope you don't get gas all over yourself.
   / Gas cans #60
Not the EXACT same. No CARB here.. Thats for you americans :D We still have the sense to not regulate gas can spouts... Who knows for how much longer though... You should make a road trip across the border and get some proper nozzles.
Is this the nozzle on yours?
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
2000 SCHWING P88 PORTABLE CONCRETE MIXER (A51247)
2000 SCHWING P88...
Scag Mower (A50324)
Scag Mower (A50324)
2011 Ford F-350 Knapheide Stakebody Flatbed Truck (A52377)
2011 Ford F-350...
Genie GTH-644 (A50490)
