mounting plates
/ mounting plates #1
candyman
oh
Kubota 2011 MX5100 W/la844 loader, ag/ tires loaded, Massey Ferguson 2010 GC2610 TLB w/ r4 tires, loaded, 60" Belly Mower
no sure if this is where i need to post this.
where can i get skid steer mounting plates { q. a. } for my kubota mx5100
i`d like to get some plates & make different attachments.
thanks,
cm
/ mounting plates
looked & could not find what i want. i just want the blank q. a. plate itself &
add what i want to it.
thanks
/ mounting plates #4
They are not hard to fab up yourself. I used to get them for about $60 bucks and it was not worth making one at that price, but lately they seem to be well over $100. I have made 6 or 7 attachments that use the std SS mount and the first few that were "store bought" will soon need beefing up, the top part of the mount is "opening" and getting loose. I just finished a dual blade road type grading blade and made the SS mount and the top pc. of metal that you slide up and under when attaching is at 45 deg. to the main plain of the mounting surface and the bottom angle that has the holes in it for the pins to lock it on is at 40 deg. Or just use your tractor as a jig and fab it up on your loader.
/ mounting plates #5
Check out ebay, they are from $75 & up. There are others out there too, just do a search for them. You can even get them as a left and/or a right side plate. Just pay attention to the thickness. I'm doing what RustyIron suggested and I'm fabing my own. Not to hard to do. This is my first try so it's not too pretty. Friend gave me a forklift carriage w/ 42" forks. The carriage is only 35" wide so I had to make a frame to attach it with. Just did the top bar of the QA component last night. I'll post pics in a thread soon.
Good luck finding what you want!!:)
/ mounting plates #7
/ mounting plates
rusty, can you post pix of your builds. ?
ghk, i`m not a welder could you post close up pix`s. ?
gwdixon , one coming to ohio in june did not find any plates but may go & see what it is all about.
tawilson, 128.00 each . how did the ones you got as described & ready to weld, what are you going to make. /
thanks, candyman
/ mounting plates #9
I welded one to a set of stone forks and the other I haven't used yet. I may make a trailer hitch setup, not sure. Very happy with the plates. 5/16" steel also. Many are 1/4" for more $ than that.
/ mounting plates #10
Here's a couple of pics. It's not you're typical "plate" but it's what works best for my application on the dual blade road grader that is shown. I don't know how to show "links" but I made a couple of posts in Build it yourself I think called grader blade but I don't think those pics. will have much to do with the mounting plates. The easy way to do it is use youre loader as a jig. The one thing that I have learned is to NOT build it too tight, make it a little sloppy, most of the factory made attachments are that way. The ones that I made that are real tight, take some fooling with to get it to latch.:thumbsup:
/ mounting plates #11
I purchased mine off eBay, manufactured by KFI. Great product.
$75 and $25 shipping.
/ mounting plates #12
Are they the full plate or the ones with the bar connecting the two receivers? I broke one of those the first time I dropped it.
/ mounting plates
searched for plates & found some 1/4, 5/16,716, thick some thicker on top than on bottom some full some partial plates, not sure what to get & how wide. ??
advise, please>>>>
thanks, cm
/ mounting plates #14
My advice is get the one on the link I posted. 5/16" plate with a 3/8" top bar.
/ mounting plates #15
Here is what I have so far....first 2 pics show the QA of the FEL laying down on the metal frame, the next 2 show the "top bar" in its proper orientation & tacked into place.
Now, before all the critics start, this is my first attempt at building anything like this from scratch:) The top bar is 1/4" thick and a bit wider (or deeper) than I would have liked but the steel was free, so I'll work with it.:thumbsup:
I cut it to length, and then cut 4 pieces at 45 degrees (matching my wooden template I made) and I have those 4 pieces supporting each side of the QA plates (2 for each side).
Sorry, the resolution is not that great b/c it is my cellphone camera!
I have laid a weld across most of it and will probably have to go back and add a second layer for strength.
I'll post more pics when done or at least getting the lower tabs in place.
Thanks for looking!
P.S. - I might go to the Ritchie auction in June and see if I can buy one of the frames they have listed??!! At least I'm having fun learning:D
/ mounting plates #17
You're doin good!!
A few thoughts from my experience, 1/4" is a little light for the top angle but should be fine if you support it (like you did on the outside edge) at a point inboard of where your quick hitch ends. Make sure that the handles move all the way through their complete motion before you weld it. BTW, it doesn't need to go all the way across. Isn't welding up your own stuff cool!
Keep in mind that the top angle does ALL the work while lifting and the bottom angle does all the work during a "backdragging" type load.
/ mounting plates #18
Thanks RI.
I have another support on the inside of each QA plate....so there are 4 total. I remeasured and the topbar is actually 3/8". Thanks!!!
Candyman - try this link on ebay.....
3/8" ATTACHMENT MOUNT PLATE SKIDSTEER BOBCAT SKID STEER | eBay
I checked the topbar on my loader bucket and it is 3/8". I would go 3/8 and thicker. Standard width on a quick attach is 44".
The price is $119 w/ free S&H. Not bad at all. Good luck!!!:thumbsup:
/ mounting plates #19
The plates I ordered were the full plate and were only $9 more. The partial plate is ok if you are welding to a bucket, but to make a trailer hitch or 3 pt. adapter I prefer the full plate.
/ mounting plates #20
Ok, I followed the ebay link to their storefront and lo, it's the same company I linked to. You can buy the full plate from the ebay storefront for $93 + $39 shipping or buy it from my link for $128 and free shipping.
211297 (A62131)
211297 (A62131)
Chery 21'x24' Double Carport (A64127)
Chery 21'x24'...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A62130)
2001...
Walnut Slabs (A65640)
Freightliner Columbia (A63689)
Freightliner...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
