mounting plates
   / mounting plates #1
candyman
oh
Kubota 2011 MX5100 W/la844 loader, ag/ tires loaded, Massey Ferguson 2010 GC2610 TLB w/ r4 tires, loaded, 60" Belly Mower
no sure if this is where i need to post this.
where can i get skid steer mounting plates { q. a. } for my kubota mx5100
i`d like to get some plates & make different attachments.
thanks,
cm
   / mounting plates
looked & could not find what i want. i just want the blank q. a. plate itself &
add what i want to it.
thanks
   / mounting plates #4
They are not hard to fab up yourself. I used to get them for about $60 bucks and it was not worth making one at that price, but lately they seem to be well over $100. I have made 6 or 7 attachments that use the std SS mount and the first few that were "store bought" will soon need beefing up, the top part of the mount is "opening" and getting loose. I just finished a dual blade road type grading blade and made the SS mount and the top pc. of metal that you slide up and under when attaching is at 45 deg. to the main plain of the mounting surface and the bottom angle that has the holes in it for the pins to lock it on is at 40 deg. Or just use your tractor as a jig and fab it up on your loader.
   / mounting plates #5
Check out ebay, they are from $75 & up. There are others out there too, just do a search for them. You can even get them as a left and/or a right side plate. Just pay attention to the thickness. I'm doing what RustyIron suggested and I'm fabing my own. Not to hard to do. This is my first try so it's not too pretty. Friend gave me a forklift carriage w/ 42" forks. The carriage is only 35" wide so I had to make a frame to attach it with. Just did the top bar of the QA component last night. I'll post pics in a thread soon.
Good luck finding what you want!!:)
   / mounting plates #7
   / mounting plates
rusty, can you post pix of your builds. ?
ghk, i`m not a welder could you post close up pix`s. ?
gwdixon , one coming to ohio in june did not find any plates but may go & see what it is all about.
tawilson, 128.00 each . how did the ones you got as described & ready to weld, what are you going to make. /
thanks, candyman
   / mounting plates #9
I welded one to a set of stone forks and the other I haven't used yet. I may make a trailer hitch setup, not sure. Very happy with the plates. 5/16" steel also. Many are 1/4" for more $ than that.
   / mounting plates #10
Here's a couple of pics. It's not you're typical "plate" but it's what works best for my application on the dual blade road grader that is shown. I don't know how to show "links" but I made a couple of posts in Build it yourself I think called grader blade but I don't think those pics. will have much to do with the mounting plates. The easy way to do it is use youre loader as a jig. The one thing that I have learned is to NOT build it too tight, make it a little sloppy, most of the factory made attachments are that way. The ones that I made that are real tight, take some fooling with to get it to latch.:thumbsup:
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
Land Honor Skid Steer Tree Puller (A50515)
Land Honor Skid...
Ford 8N Tractor w/3pt. Buck Saw (AS IS) (A50774)
Ford 8N Tractor...
2012 Ford Escape Limited SUV (A50324)
2012 Ford Escape...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50774)
PLEASE CHECK...
