How close to flush will a plasma cut?
   / How close to flush will a plasma cut? #11
5" Metal Zip Cut - Tools - Northland Construction Supplies
most welding supplies carry them, they are often a better choice than either torch or plasma... much cleaner cut, virtually no thermal distortion. like any abrasive, you have to protect against the spark trail embedding into paint.
careful with your fingers and always use eye and (if possible) face protection.:)
edit; always think in terms of the cutting plane when using these... keeping things flat is important, you only want to cut with the outside edge of the wheel... these are NOT grinding discs.
Gotcha! I have some thin cut off wheels that appear similar, just never heard the term zipcut before. BTW the linked description puzzled me a bit how an almost 1/2 inch thick wheel, .45" it said, could be good for cutting, turns out looking elsewhere that was supposed to be .045", they had a typo;)
   / How close to flush will a plasma cut? #12
Thanks for all the replies. I did the outside ears a year ago and left the inside ears as a stiffener. Now I have a QT loader so the other ears need to go. I don't recall this being fun. I used a torch, but I suck with a torch. I thought maybe a plasma might make it less painful. After looking a the pic again the fillets look small so maybe a cutting disc is the way to go as rjmack mentioned. I think I have some for my electric grinder.
A plasma cutter I think is easier to use than a torch if you're not use to using either. But if you don't own a plasma cutter I wouldn't buy one unless you have use for one to do multiple jobs or or future plans. For a couple of bucks each you can buy a lot of cut off wheels for the cost of a plasma cutter.
   / How close to flush will a plasma cut? #13
thats a good point. i paid $2200.00 for my plasma cutter, used it on one job (cutting up a truck cab) and though it was an excellent tool for that job, it has been pretty well useless for steel fabrication... i have never been able to come anywhere near torch quality cutting with my plasma.
i can see using them in bodywork or fabbing light guage steel (or stainless and aluminum) but that's about it.
having said that, i had much better luck cutting checkerplate aluminum with a jigsaw... less thermal distortion than plasma.
   / How close to flush will a plasma cut? #14
your doing something wrong then plasma makes a very clean cut. post up some pics.
   / How close to flush will a plasma cut? #15
No use for Plasma in the Metal Fab World? Plasma " Should " cut as well as a saw with more accuracy than a cut off wheel. You can turn it up or down. Man..What Brand are you using??
   / How close to flush will a plasma cut? #16
i have a hypertherm 1000 and i cut aluminum checkerplate all the time. does a great job and no distortion.
MInd you mines on a cnc table moving at a fast clip. maybe your moving too slow.
I get very nice percision in metal fab work. This is in some 3/16 and 1/4" stock
   / How close to flush will a plasma cut? #17
I've use my plasma on everything from think aluminum to 1/2 thick steel and it cuts very cleanly. You DO need to have a supply of clean DRY air and good clean tips. I've found that if I don't keep my air dry it will eat my tips and then I'll slag from h@ll.
   / How close to flush will a plasma cut? #19
Here's some nifty cutting my brother-n-law did.
   / How close to flush will a plasma cut? #20
Has anyone seen or used this plasma machine?
Multiplaz. Welding, Cutting, Soldering, Brazing...
I saw the early vesion of this at an AWS/Fabtech show in the late 90's.Since then there has been several versions that say they can tig, braze and cut. They kind of do but very slowly and not very efficiently. I know a guy who moved here from Russia and he had a version that Actually, ( believe it or not ) Ran on Vodka instead of water and alcohol. He wanted $1400.00 for them.
(APPROX 50) 2" X 2" X 97" TUBING (A51247)
(APPROX 50) 2" X...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A51248)
UNUSED WOLVERINE...
2016 CATERPILLAR D6K2 LGP CRAWLER DOZER (A51246)
2016 CATERPILLAR...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
UNUSED X-STAR 750 GALLON FUEL TANK (A51247)
UNUSED X-STAR 750...
