how much to rebuild my TC21d engine?
   / how much to rebuild my TC21d engine? #1
BREED
Fredonia, NY area
New Holland TC21d
I have a great little tractor which I inherited but it is getting a little tired.
How much would/should it cost me to have it rebuilt?
Just for grins is a new engine worth it?
THanks in advance
   / how much to rebuild my TC21d engine? #2
THanks in advance
if the tractor is in good working order an everything works on it,then i would have a new motor put in it.but if the motor cost $2000 or more it might be better to get a new tractor.
   / how much to rebuild my TC21d engine? #3
How many hours?
Why do you think it is "tired'?
Have you done a compression test?
Have you had the injectors tested?
A "rebuild" covers a wide range of methods and processes some necessary each time, many not. Anyone quoting a rebuild without knowing a lot more about the condition of the engine really doesn't have a clue.
A long block for an early TC21D runs well over $8000 which is likely more than the tractor is worth in many markets.
   / how much to rebuild my TC21d engine? #4
How many hours?
$8000 for a long block on that size tractor you got tobe kidding.we payed $7000 for a new engine for a 7700 ford in 91.
How many hours?
1200 + hours
smokes pretty good under load.
I have not had any testing done
give it a try, thanks to all
   / how much to rebuild my TC21d engine? #9
1200 hours?? It's not even broke in yet!!?? ;)
   / how much to rebuild my TC21d engine? #10
Change the air filters and run a couple tanks of fuel with a good conditioner through it.
i would have to agree but i would also change the fuel filter then if that doesn't work i would have the injectors checked and check for a salvage motor at a salvage yard if needed to
these tractors have some high dollar parts inside of them i cost me around 1000 just in parts to put rings rod bearings and a complete gaskett kit in a 1320 ford and there is alot more higher dollar parts inside of one of these
6" & 8" I BEAMS, 2" X 2" TUBING, 2" X 2"ANGLE IRON (A51247)
6" & 8" I BEAMS...
2023 CASE TV620B SKID STEER (A51246)
2023 CASE TV620B...
2006 Husqvarna YTH2148B 48in Riding Mower (A51694)
2006 Husqvarna...
2025 AGT 750 (A50123)
HANG ON MAST W/ 58" FORKS (A51247)
HANG ON MAST W/...
HYUNDAI 30D-9 STRAIGHT MAST FORKLIFT (A51246)
HYUNDAI 30D-9...
