how much to rebuild my TC21d engine?
   / how much to rebuild my TC21d engine? #1
BREED
Fredonia, NY area
New Holland TC21d
I have a great little tractor which I inherited but it is getting a little tired.
How much would/should it cost me to have it rebuilt?
Just for grins is a new engine worth it?
THanks in advance
   / how much to rebuild my TC21d engine? #2
THanks in advance
if the tractor is in good working order an everything works on it,then i would have a new motor put in it.but if the motor cost $2000 or more it might be better to get a new tractor.
   / how much to rebuild my TC21d engine? #3
How many hours?
Why do you think it is "tired'?
Have you done a compression test?
Have you had the injectors tested?
A "rebuild" covers a wide range of methods and processes some necessary each time, many not. Anyone quoting a rebuild without knowing a lot more about the condition of the engine really doesn't have a clue.
A long block for an early TC21D runs well over $8000 which is likely more than the tractor is worth in many markets.
   / how much to rebuild my TC21d engine? #4
How many hours?
$8000 for a long block on that size tractor you got tobe kidding.we payed $7000 for a new engine for a 7700 ford in 91.
How many hours?
1200 + hours
smokes pretty good under load.
I have not had any testing done
give it a try, thanks to all
   / how much to rebuild my TC21d engine? #9
1200 hours?? It's not even broke in yet!!?? ;)
   / how much to rebuild my TC21d engine? #10
Change the air filters and run a couple tanks of fuel with a good conditioner through it.
i would have to agree but i would also change the fuel filter then if that doesn't work i would have the injectors checked and check for a salvage motor at a salvage yard if needed to
these tractors have some high dollar parts inside of them i cost me around 1000 just in parts to put rings rod bearings and a complete gaskett kit in a 1320 ford and there is alot more higher dollar parts inside of one of these
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
Wacker Neuson DT08 (A50123)
Wacker Neuson DT08...
2012 Honda Pilot SUV (A51694)
2012 Honda Pilot...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
