2520 - Running Out Of Power
   / 2520 - Running Out Of Power
Hi,
I would check the fluid level. Is there fluid in the sight glass when on level ground? Did you pull the dipstick and verify the level? (it's below the range selector lever, you'll need a rod to hook the dipstick and pull it out.)
Hydrostats make noise if the pump picks up air and they don't have any power at that point either. (The guy next door found this out on his Cub lawn tractor last year)
If your backing up a hill and the fluid level is low you could be uncovering the pickup for the pump which I believe is to the rear on the 2x20 series. (not 100% on that though)
Tom
You are going to have to show me a picture of the dipstick, all I have is a fill cap and there is nothing in it, I reached down in there as far as it goes.
As for the sight glass, it looks red, but I can't tell if it is full empty, I assume full since the fluid is red.
Ok. So I found it. Thanks for the pic. It was clear full.
   / 2520 - Running Out Of Power #17
My tractor was very low on trans fluid when they delivered it. They never added to the system after installing the loader.
2008 Ford F-450 Crew Cab Service Truck (A52377)
2008 Ford F-450...
2012 Peterbilt 337 IMT 6025 14,000lb 5 Ton Crane Mechanics Truck (A53422)
2012 Peterbilt 337...
Miller Big 40 Portable DC Arc Welder Generator (A52377)
Miller Big 40...
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
8' SMALL FENCE POSTS (APPROX. 40-50 PC) (A54757)
8' SMALL FENCE...
UNUSED HURRICANE STAND ON SKID STEER (A52706)
UNUSED HURRICANE...
