2520 - Running Out Of Power
   / 2520 - Running Out Of Power
Hi,
I would check the fluid level. Is there fluid in the sight glass when on level ground? Did you pull the dipstick and verify the level? (it's below the range selector lever, you'll need a rod to hook the dipstick and pull it out.)
Hydrostats make noise if the pump picks up air and they don't have any power at that point either. (The guy next door found this out on his Cub lawn tractor last year)
If your backing up a hill and the fluid level is low you could be uncovering the pickup for the pump which I believe is to the rear on the 2x20 series. (not 100% on that though)
Tom
You are going to have to show me a picture of the dipstick, all I have is a fill cap and there is nothing in it, I reached down in there as far as it goes.
As for the sight glass, it looks red, but I can't tell if it is full empty, I assume full since the fluid is red.
Ok. So I found it. Thanks for the pic. It was clear full.
   / 2520 - Running Out Of Power #17
My tractor was very low on trans fluid when they delivered it. They never added to the system after installing the loader.
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A52377)
2019 Allmand...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
UNUSED LANDHONOR HPF-11-3000G HYD PALLET FORKS (A54757)
UNUSED LANDHONOR...
Toro Multi Pro 5800 (A53424)
Toro Multi Pro...
1984 Ford LTD Crown Victoria (A52377)
1984 Ford LTD...
New Holland 325 Manure Spreader (A55218)
New Holland 325...
