using hydraulic motor as a brake drag
   / using hydraulic motor as a brake drag
How soon would you wear out the brake pads, I would assume that it wouldn't take that much braking though to hold it back. Thanks for the suggestion, I'm going to look into that.
   / using hydraulic motor as a brake drag #12
Rock$oldsano, I dont think they ever wear out, I know of one getting hot, cuz The owner, left them on on took off down the road, The adjuster, is nothing more than a fabricated linkage that you set manually to cause drag,..A hand wheel mounted on a threaded shaft, applying shoe contact, there are lines about 8in long on the bag, and you adjust the brakes to strech the lines to about 10in or so, Eric
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A55973)
2012 International...
110 GALLON FUEL TANK (A52708)
110 GALLON FUEL...
Jumbo Quartz Slab 127.5" x 63.75" (new/unused) Est. Retail $2,200 (Pickup Location: Atascadero, CA) (A59225)
Jumbo Quartz Slab...
2007 FORD EXPLORER (A58214)
2007 FORD EXPLORER...
LOT: Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Fuel Transfer...
NIPPON HYD THUMB (A52706)
NIPPON HYD THUMB...
