using hydraulic motor as a brake drag
   / using hydraulic motor as a brake drag
How soon would you wear out the brake pads, I would assume that it wouldn't take that much braking though to hold it back. Thanks for the suggestion, I'm going to look into that.
   / using hydraulic motor as a brake drag #12
Rock$oldsano, I dont think they ever wear out, I know of one getting hot, cuz The owner, left them on on took off down the road, The adjuster, is nothing more than a fabricated linkage that you set manually to cause drag,..A hand wheel mounted on a threaded shaft, applying shoe contact, there are lines about 8in long on the bag, and you adjust the brakes to strech the lines to about 10in or so, Eric
2022 Ford Escape S AWD SUV (A54815)
2022 Ford Escape S...
2016 FORD F350 FLATBED TRUCK (A58018)
2016 FORD F350...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
23013 (A55787)
23013 (A55787)
2014 Ford Taurus AWD Sedan (A56859)
2014 Ford Taurus...
2022 Horizon Trailers DH8BP-2 15ft 5 Ton T/A Dump Trailer (A55973)
2022 Horizon...
