crank and crank
   / crank and crank #11
does it feel like it has plenty of power? sounds like a diesel with low compression to me.
smokes and difficulty fireing, but once warmed fires up ok... that's a pretty good sign of low compression.. though not 100% limited to that.
soundguy
   / crank and crank
no problem with power,has plenty,when running dosn't miss a beet
   / crank and crank #13
I usually preheat the glow plugs, then start at full throttle. As soon as it starts I move the hand throttle. Winter starts sometimes require a back and forth throttle action, until it will run smooth.
   / crank and crank #14
   / crank and crank
no where is it located??
   / crank and crank #16
um.. look at the intake manifold.. and follow the tube.. it will eventually end in a canister with a breather element !
soundguy
   / crank and crank
pulled the glow plugs the other day,tested them with leads to the battery,two are dead,the other,only smoked a little did not glow,so ordered three new plugs $50.00 each,should get them today,and my issue should be solved thanks guys & gals
2017 John Deere 5090GN (A53317)
2017 John Deere...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
CAT Chassis Only (A59076)
CAT Chassis Only...
Hidratrak 8' Rolling Cultivator (A53317)
Hidratrak 8'...
John Deere 690B Excavator with Auxiliary Hydraulics (A57024)
John Deere 690B...
2020 Deere 750K LGP (A53317)
2020 Deere 750K...
