crank and crank
   / crank and crank #11
does it feel like it has plenty of power? sounds like a diesel with low compression to me.
smokes and difficulty fireing, but once warmed fires up ok... that's a pretty good sign of low compression.. though not 100% limited to that.
soundguy
   / crank and crank
no problem with power,has plenty,when running dosn't miss a beet
   / crank and crank #13
I usually preheat the glow plugs, then start at full throttle. As soon as it starts I move the hand throttle. Winter starts sometimes require a back and forth throttle action, until it will run smooth.
   / crank and crank #14
   / crank and crank
no where is it located??
   / crank and crank #16
um.. look at the intake manifold.. and follow the tube.. it will eventually end in a canister with a breather element !
soundguy
   / crank and crank
pulled the glow plugs the other day,tested them with leads to the battery,two are dead,the other,only smoked a little did not glow,so ordered three new plugs $50.00 each,should get them today,and my issue should be solved thanks guys & gals
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
Link-Belt 75X3 (A53317)
Link-Belt 75X3...
2002 Frieghtliner Pressure Digger Truck (A55973)
2002 Frieghtliner...
Ingersoll Rand SD-116DX TF (A53317)
Ingersoll Rand...
excavator trenching bucket- one bucket per lot (A56436)
excavator...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
