Hello
I recently purchased a Hydraulink for use on my new Kubota
B2320 while using a box blade. I wanted to share my observations for those who might be on the fence about buying one. I bought mine at Agri-supply (best price around) and shipping was quick. Let me start by saying I had realistic expectations of it's use and limitations. I did not think this was a substitute for a hydraulic top link powered from the tractor hydraulics. I don't want to debate or make representations that this is the case. Instead I bought hydraulink knowing that it is merely a tool to make three point use more convenient especially if u do not have rear remotes on your tractor.
First impressions of the unit were a stoutly built little piece with very good quality machining and welding apparent.
The unit is easy to use and I like the versatility of being able to make quick adjustments on the fly. Having this flexibility make hooking up to attachments much easier. Using a box blade this feature makes pitch adjustments easy in order to change the aggressiveness of the cut In addition making rapid pitch adjustments allows me to increase the attachment clearance when loading on my trailer ramp. Naturally these adjustments could be made using a regular top link but with the hydraulink they are much faster.
The shock absorber effect of the unit also works well and is noticeable in the way the blade performs
I am happy overall with the unit and would recommend one.
Greg
