2011 L3800 jerky three point hitch fixed?
   / 2011 L3800 jerky three point hitch fixed? #1
jokergerm
Gold Member
Well after two hours of my new tractor the jerky hitch is driving me insane
I called the dealer and they sent out there mechanic and he said 100% that's wrong and he will fix it. They said the older ones had this issue but the newer ones are fixed. They are coming Monday to take it in and fix it
I asked what happens if they can't fix it and they said I would get A different tractor that didn't do that
The funny thing is. The three point was smooth for the first hour and it started today to get really jerky. I'm just hopeful they will stick to their word and make it right some how
   / 2011 L3800 jerky three point hitch fixed? #2
Just a shot in the dark,but sounds like you might have a leak somewhere,or on an end clamp on a return hose.
Do you have an FEL on it ?
Was that acting up also ?
I'am no expert but only jerky 3pt. issues I ever heard of were on the L2800/L3400'S,and that was mostly on the pre 70xxx serial #'s.
Boone
anyone else?
   / 2011 L3800 jerky three point hitch fixed? #4
anyone else?
Would love to hear if they fix it... or if they want you to upgrade to the Grand L. If they do fix it, try and find out what they did....
i hope they cant fix it and they upgrade me that would be sweet! they were shocked when they came to my house and saw it. They made me feel really good they acted like they felt really bad and would make it right, i just hope that is the case.
they kept talking about some valve being clogged with something or adjusting it, either way something will happen to make it right, keep your fingers crossed
i was right in the middle of a project when they came to look at it, and they told me to finish up what i was doing this week and monday they are picking it up to try and fix it.
The mechanic was like, "there is no way you could even use your auger with it shaking like that"
   / 2011 L3800 jerky three point hitch fixed? #6
The auger was the only time I liked the jerk... it knocked off the dirt really well. :D ...but that was back when my PTO didn't turn off :mad: If they upgrade you... it'll cost you some (but might be worth it).
hmm i would throw out another 2k maybe to upgrade but no more. Ill see what they say
   / 2011 L3800 jerky three point hitch fixed? #8
I don't think anyone has ever reported having a L3800HST that was NOT jerky, so don't hold your breath for a fix. Mine (delivered this spring) certainly is jerky (but it doesn't bother me, personally).
You know that the jerkiness only happens for small increments, right? A large change in the position control will have a smooth lift.
- Mike
Ya I got that, but I'm going to br drilling 100+ holes and grading my driveway. It's at least worth to see what happens
well i just got back from the dealer, i went to see how the other tractors 3 point hitches are and guess what they are the same. No way! JK
anyways the dealer claims they have never heard of this with the L-series and they say that its not ok and they will make it right or get me a tractor that does not do this.
The sales guy said i totally understand i would be pist also and i would demand that it was fixed. they are going to LOOK at fixing it on monday and then if they cant, they are going to work on upgrading me to the Grand L
wish me luck folks
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
GEARMATIC WINCH (A58214)
GEARMATIC WINCH...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A56438)
2016 KBH...
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
7021 (A55851)
7021 (A55851)
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
