1401 PTO issue URGENT!! Need to fix!!!
   / 1401 PTO issue URGENT!! Need to fix!!! #11
It sounds like the PTO gears aren't fully engaging, so are popping out when the thing is heavily loaded. My 1401D has solid detents that really click into place tightly, but it's easy to over or undershoot getting them in. Are you sure that you're all the way into the gears? Does the lever move at all when the grinding starts?
As far as the PTO shaft spinning with the rototiller not moving, I checked and there is NO MOVEMENT of the PTO shaft.
I agree that it seems as if the PTO gears are not fully engaging. I will experiment with moving the PTO lever and see what happens.
So far no one seems to have had a similar issue. The main concern of those that have responded is that I cannot tell if it's the tiller or the tractor; thus checking the PTO shaft rotation against the tiller coupler is the method of establishing which it is.
IT is the tractor NOT the Tiller. What could be causing the issue? What do I look for if I pull the housing? Does anyone have any experience working on the PTO component of a Yanmar?
Thanks,
Jon
   / 1401 PTO issue URGENT!! Need to fix!!! #13
THanks Winston
I'll read 'em.
Jon
   / 1401 PTO issue URGENT!! Need to fix!!! #15
Before id pull id i would hook a bushhog or some other pto implement and goo cut some tall grass and see it that grinds too, that will easily tell you the tractor or tiller. But also the whole PTO pulls out of the tractor as an assembly, just remove the bolts on it from the back of the tractor.
   / 1401 PTO issue URGENT!! Need to fix!!! #16
Yes, I was going to suggest the same thing. I have a 169D which is the domestic model to the 1401D. In my manual it shows the gears for your PTO. I have seen the inside of the tranny on my 169D but i took off the hydraulic assembly because I had a seal go out on the cylinder. It wasnt a hard job, but you will get a lot more access to the PTO that way. I didn't see it in too much detail as I had hydro fluid in there but it isn't to complicated. Hoye may have the parts needed as they have several whole 1401's in parts. If you don't have one already, I greatly suggest getting a parts manual, it helps a lot when it comes to things breaking because it gives you parts numbers and a good image on how everything goes together and how it all works. I have attached a few pictures from my manual and of when I had my Yanmar apart in the hydraulic cylinder seal replacement.
Clemsonfor:
Yesterday I did watch what happened to the PTO shaft when the grinding occurred.
I slowly lowered the rototiller while the pto shaft was engaged and the tines were rotating.
At about 3-4 inches engagement with the ground the rototiller stopped moving along with the PTO shaft and the tractor. That is to say when the PTO was grinding and the rototiller was stopped, and the tractor would not move.
I tried to move the PTO selection lever while the tractor and the PTO was grinding/stopped. This did nothing as the selection shaft would not budge until the clutch was disengaged.
This will have to do as confirmation that it IS the tractor in my opinion; as I do not have a brush hog or other PTO driven attachment nor do I have access to one. I then decided to test the clutch to see if the splines on the coupling between the clutch and transmission was damaged.
To do this I put the tractor in low/first gear against a stout tree. The tractor engaged all four wheels and dug itself into a 1 foot hole without any grinding or slippage of the clutch.
I suppose that I'll have to start looking for help at identifying what is broken in the PTO. Either that or dump the yanmar and buy a new tractor.
Thanks for the input.
Jon
Johndeere3720:
Thanks for the help with my problem. I am going to assume that you read my post to 'clemsonfor' above.
I looked at your tear-down pictures along with your copy of the manual. I do have the manuals that go with the tractor.
My understanding from looking at what you posted is that the drive to the rear tractor wheels and the PTO are directly related yes? That is to say some components are shared between the functions of running the tractor drive-train and running the PTO.
Do you have to remove the tire to get at the PTO or was that to facilitate your access to the seal you mentioned?
I was intending to call HOYE today and talk with them about this issue to see what feedback I'd get. Any other source of technical help you know about?
Thanks again for the assist.
Jon
   / 1401 PTO issue URGENT!! Need to fix!!! #19
does the PTO & tiller still engage at a certain 3 pnt hight? Do you have a way to post pictures of the way the tiller drive shaft is connected?
has this tractor and tiller always been mated up together for use? or is it possible that the tiller had been setup to be used with either smaller or larger tractor at one time?
Is the drive-line from the tractor to the tiller slide as the tiller raises and lowers? when you mention that the tractor started making the grinding noise just after the tiller drops at a lower level it had curious about the drive-shaft connection or the angle of the drive-line, if the shaft does not slide with the movement of the tiller it could pull excessively against the PTO shaft gears and inner casing,
I suppose I'm looking at more of the cause than the fix, although sometimes it helps to better know how to fix something when we know what cause the problem in the first place,
here is something i found helpful,
http://www.google.com/imgres?imgurl...=2&ndsp=20&tbm=isch&ei=NbQETtauF4HZgAeMrsSwDQ click how to rotary
Is the drive-line from the tractor to the tiller a rigid connection? or does it slide as the tiller raises and lowers? when you mention that the tractor started making the grinding noise just after the tiller drops at a lower level it had curious about the drive-shaft connection, if the shaft does not slide with the movement of the tiller it could pull excessively against the PTO shaft gears and inner casing,
Hi:
Yes the PTO and tiller will work as long as the tines are not under load. It doesn't take much. Tilling in soft pre-tilled earth (I have a larger tractor that has rototilled the area used to test the 1401) it will work up to about 3 inches deep. Any deeper and it abruptly ceases to work accompanied by a horrible grinding sound. The other problems are described above.
There are pictures of the tiller set-up in a previous posting on this thread. These show the coupling between the tractor and tiller as well as a view of the tiller and tractor. The tiller is designed to work with the Yanmar specifically. The tiller is not modified in any way.
IF these pictures are not clear enough I can always upload some more.
Thanks for your input,
Jon
2001 FORD F-350 XL SUPER DUTY FLATBED TRUCK (A60430)
2001 FORD F-350 XL...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A60429)
2021 CATERPILLAR...
2017 CHEVROLET SILVERADO 2500HD (A58214)
2017 CHEVROLET...
2019 GALYEAN...
2007 MACK GRANITE CV713 DUMP TRUCK (A60430)
2007 MACK GRANITE...
