ford 1700
   / ford 1700 #41
Can Anyone tell me how to put my steering Box Back together. I Disassembled it to put New Bearings in it & now I can not get it back together. It seems to bind or Not go together. What am I Doing Wrong?
Any Help would be Appreciated...
Thanks
   / ford 1700 #42
Thanks
Have not done that particular repair. Did you put a witness mark on the final shaft connected to steering arm? look at the attachment below. I think your problem is with the part #2,sector shaft and the balls or initial location of part#3 shaft in reference to #2. Is it bound up in one direction or both?
JC,
  • 1700 steering.pdf
   / ford 1700 #43
I Think it is too. I am going to mark it & try it w/o bearings, Until I get it right. I mashed 2 sets of bearings, trying to get it right. I Don't know if #2 should be centered on #3 or totally at the bottom of the shaft. It seems like Center should give me Both left & right turns w/o binding. Thanks for the help. I had that print out from the Newholland.com web page. Finding the bearings for cheap is my next problem. The dealer wants $60 Each for a
1 7/16" OD dia Race bearing. Little junky Bearings.
   / ford 1700 #44
If you can identify the bearing spec the outfit linked below might be able to get the same bearing pretty reasonable. If yo have a local distributor you can simple take the old bearing there and they'll match it up for you.
JC,
Industrial Supplies | Bearing Distributor | Material Handling | MRO | Safety | Training
   / ford 1700 #45
I just found a 1700 with a FEL for $4600. It also comes with a rake attachment. It has 1425 hours. Good deal or not? From the pics, the tires look good.
This will be my first tractor so I have a lot to learn. I will use it for mowing about 2-3 acres and plowing a 1100' drive in the winter.
   / ford 1700 #46
It is a good deal. A very good tractor.
   / ford 1700 #47
It is a great deal with the fel. is it a well maintained tractor?any pics?
JC,
   / ford 1700 #48
Hello to everybody, i own a ford 1700 and a'm trying to find the cylinder head for it, if you have some information i'll be very gratefull
   / ford 1700 #50
Where? how much did it cost you??
Thanks
2020 Deere 544L (A60462)
2020 Deere 544L...
Hyster H155 XL Forklift (A59213)
Hyster H155 XL...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
EZ loader trailer (A56857)
EZ loader trailer...
40' 1 Trip Shipping Container (A59814)
40' 1 Trip...
Schuler 125BF Feed Wagon (A59814)
Schuler 125BF Feed...
