Splitting Rock Questions
/ Splitting Rock Questions #21
I suppose it works because the gasses expand so quickly that the rock cracks before it has time to expel the putty. If you don't pack enough putty or don't pack it sufficiently it can blow back out the hole. It takes practice - how much pyrodex to use or how many holes to drill or how deep to drill depends on the size of rock, type of rock, and whether you're talking bedrock, or loose boulders. Loose boulders are good, they are much easier to shatter with fewer pellets. If you use too few pellets or try to take too much rock off at once, it will just make a muffled sound and nothing will crack. If you use too much, it's best to be in a safe place, as rock projectiles will fly everywhere. Sometimes we use too much on purpose heh heh. Obviously you can't use this method next to a home or in town, etc. If you use just the right amount, it makes a relatively quiet noise and cracks the rock with no projectiles. I use a Bosch 36 volt lithium-ion hammer drill with a couple spare batteries for the holes. Having a generator and line powered hammer drill would be faster...
What would you consider to be a "safe distance"? The nearest house is about 150 feet away. Too close? :cool:
/ Splitting Rock Questions #22
I've got one chunk of bedrock at a bad spot in my driveway. After looking into getting the local blaster (we can no longer DIY here) I priced the chemical method--would be almost the same price.
Might just dig out my 18"x 1/2 "carbide drill bit.....got no source for cannon fuse yet but I'm looking...
/ Splitting Rock Questions #23
I'll let you in on a little secret. We use this method to "mine" our way through constrictions in cave passages to find new cave. Get some pyrodex pellets, I think they are .50cal? Anyways they are 1/2" in diameter pellets. Get a long 1/2 SDS+ hammer drill bit and drill. Drill the hole as deep as you want or can. The pyrodex has holes in the center that happen to match up with cannon fuse. Feed 5 or 6 onto the cannon fuse (or 10 or 12), slide them into your hole in the rock. Pack plumbers putty into the hole but being careful not to tear up the cannon fuse. Light and hide behind something. Your rock will be shattered. May have to take it apart in sections....
Another choice would be a 50/50 mix of sodium chlorate and sugar. Pack wet sand around the fuse. It's worked well for me.
/ Splitting Rock Questions #25
I used plain old fire under a large rock to split it !! do a search under 'large boulder must go' I burnt up a bunch of old half rotted wood and got the rock good and hot over night each time a large pcs wood crack, and my cost "0"
/ Splitting Rock Questions #26
This "Boulder Buster" look like a pretty interesting tool. Uses what looks like a shotgun shell and water to create pressure shock to split rocks. Like any of the techniques mentioned the hardest part of the job is drilling the hole to pour the water into. The upside is there is only one hole needed. Pretty cool video demonstrating the product.
Boulder Buster - Power Tools - Mays Trail Equipment
/ Splitting Rock Questions #28
Carl Bert said:
Wow, that looks like a great system. With July 4th right around the corner, I can easily get away with the loud bangs, I'm sure it produces. Can't wait to find out the price. My guess is it's going to be in the $400-$500 area. I will let you know tomorrow.
Closed today, will try again tomorrow.
/ Splitting Rock Questions #32
Holy boulder buster Batman!!!! I was quoted a price of $3,995++++, Plus tax, plus shipping, plus loads, plus heavy loads +++. I still can't see where this little gadget is worth over $4500. I can buy a hyd hammer for my B26 for just over $6000. Much better value in my opinion.
Oh well I guess I will be ordering some cannon fuse, and see if I can split some rock, without blowing myself or the neighbors house up. Wish me luck.
Man if I spent 5 grand and thing didn't split my rock(s) the next shot would be test in someones back side. I believe you could reverse engineer this for couple hundred bucks.
/ Splitting Rock Questions #34
How many people here remember the days when you could get dynamite at the local hardware store? Then you needed a class and permit and now I'm not sure what it entails to use it.
Wedge
/ Splitting Rock Questions #35
Try and use the Dexpan or similar type product.....We have had VERY good luck with it and its easy to use. Check with your local equipment rental yard for a rock drill package (towable air compressor / rock drill / 4' or 6' shaft / drill bits) they usually rent for around $150.00 per day...the dexpan type product sell for around $100-$120 per box.....Drill holes all over rock pour in material and it cracks rock.....FYI place a tarp or other cover over rock if near cars building sometimes not all holes work and the product will fire back and the dexpan material will shoot out kinda like a volcano (not dangerous just a pain to clean off a car hood)
/ Splitting Rock Questions #36
You could try an oxygen lance, basicaly a 10 foot long pipe with a bundle of iron rods in it. You hook it up to an oxygen regulator and light it with a road flare or a sparker device ( a file hooked onto a car battery) these things burn hot enough to burn through steel, concreat, and stone. look for a video of one on youtube.
/ Splitting Rock Questions #37
We split some rocks, rocks heck, bolders, using feathers and wedges. You can google it. We split tons of bolders to build a greenhouse.
/ Splitting Rock Questions #38
those thinking of cannon fuse? It could be trouble if the fuse burns faster then it is supposed to. Better use lamp cord, a length of lamp cord just cut the female end off strip the wires back place that end in the charge of black powder or similar material. plug it is and boom. I would suggest a long extension cord and have everything unplugged then start at the charge and work your way back to the power source. Of course i do not recommend this and advise getting a "pro" to do it, but then I am just being careful as should you.
/ Splitting Rock Questions #39
Just use a really long piece of cannon fuse and run:D
/ Splitting Rock Questions #40
You forgot deereman, you got to say "feets don't fail me now":laughing:
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
17in. Tooth Excavator Bucket (A60352)
17in. Tooth...
2012 Mazda 3 Sedan (A61569)
2012 Mazda 3 Sedan...
Hyster H90XMS Forklift (A59213)
Hyster H90XMS...
2025 SDLGC100 6 Passenger Electric Cart (A60352)
2025 SDLGC100 6...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
