TRACTOR WEIGHTS
   / TRACTOR WEIGHTS #31
hard to beat free material...
   / TRACTOR WEIGHTS #32
It took some patience, but I found my (5) Kubota weights on craigslist for $25 each. I just saved a link for "suitcase weights" and checked it everytime I remembered.
   / TRACTOR WEIGHTS #33
I prefer to buy tractors with weights already installed, so I don't have to worry about it. So far 3 out of 5 have had them, and plenty of them at that...Money I didn't have to spend to get OEM ones.
David from jax
   / TRACTOR WEIGHTS #34
David from jax
Thats smart but on a small tractor i dont think i would not buy one just cause it did not have $200 worth of retail weights on it. If i does all the better.
   / TRACTOR WEIGHTS #35
sme here.. when i go buy a tractor.. if it has weights great.. if not.. and it's a good deal.. I still take it.
soundguy
   / TRACTOR WEIGHTS #36
i cast some concrete weights and hung them on the front of my ford 4600 I mow with as I have to trailer up a steep incline and with a hd 6' mower on the back it was getting a lil soft in the front.
soundguy
Soundguy, you're always coming up with good ideas. :thumbsup:
What did you use for the skeletal makeup (reinforcement) of those concrete weights?
And is the bolt head through a piece of angle?
And yes, if anyone don't like the looks of concrete, they could be cast in the shape of suitcase weights and painted black. They would look like they belonged on the tractor. :cool:
   / TRACTOR WEIGHTS #37
i have a web of fence wire in the middle of the crete, plus a bent to shape piece of #10 brace wire. bolt head is a carriage style and slid thriu a 2" or so washer... wire encircles the bolt a couple turns as well..
i painted mine black and at 5' you can't tell they are not cast iron..
soundguy
   / TRACTOR WEIGHTS #38
Thanks, Soundguy. :)
My old heavy Servis mower like yours, made my front end light, too. I had thought about using concrete blocks, but hadn't thought about casting my own up that would bolt on. :confused2:
I ended up getting some iron at a local scrap yard and made up some weights with my AC crackerbox welder.
If there comes a time that I need more weight though, I'm going to borrow your idea. :)
   / TRACTOR WEIGHTS #39
You can even build a box in whatever shape u want and put the wire and rebar in it and bolts in whatever pattern you need and pour it up.
   / TRACTOR WEIGHTS #40
the bolts and wire all came from my used / scrap bin.. the only cost I had was the bags of concrete.. and they were leftovers from a fence project.. so it was more or less a 'raid the scraps' free project for me.. :)
can't beat free.
and yup.. them servis mowers sure are heavy... mine was free and all clapped out.. but mows fine.. and i don't care about hitting burried treasure with it.. :)
soundguy
Hand Truck (A52377)
Hand Truck (A52377)
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
Toro Multi Pro 5800 (A53424)
Toro Multi Pro...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
