Seat is too far back from wheel for me BX24
   / Seat is too far back from wheel for me BX24 #1
cwilliams2000
Member
I love my BX, in fact I pretty much love just about everything....Except when I mow I just am too far from the seat so I can lean back and be really comfortable. It is adjusted all the way up, and im 5'10 but 30" leg so maybe thats the issue or my arms are too short :) Not really sure, but is there anyone here who has had this issue and done anything to move the seat or make it more comfortable. Than you
   / Seat is too far back from wheel for me BX24 #2
I'm about the same height and leg length and have the same issue. I wind up sitting up really straight or leaning forward to drive. I think some kind of pedal and steering wheel extensions would be the only solution given the seat mechanism. I hope one of the master builders here has a creative solution!
   / Seat is too far back from wheel for me BX24 #3
I have the same problem with my Kubota B2320---
Had a peek at how it is mounted---2 brackets hold it on----there are two bolts on each side & one emptl bolt hole in each bracket.
I'm thinkin I can change the bolt configuration using the 2 empty holes to move the seat forward----but I have not doe that yet----Maybe today I will.:D
   / Seat is too far back from wheel for me BX24 #4
Well I just changed the locations of the seat bolts----Easy job except repositioning the metal piece that pushes on a switch. It would have been better if I had someone to hold the seat while doing this.
It is way better now for me----closer now to the pedals----
Made a big differance :D
   / Seat is too far back from wheel for me BX24 #5
I also had the same complaint. If I moved the seat as far forward as possible and then tilted the seat forward, I could see that there were still some more notches available in the seat track. I seem to recall that there was a tab that prevented the seat from sliding any further forward. I removed the tabs and the seating position is more comfortable now.
   / Seat is too far back from wheel for me BX24 #6
That is exactly what I did. A lot more comfortable now...
   / Seat is too far back from wheel for me BX24 #7
Guys - do you have pictures of your modifications? That would be a great help.
   / Seat is too far back from wheel for me BX24 #8
The attachment above shows seat brackets bolted in the forward bolt holes on the seat that were empty. You can see the empty bolt holes ( at Top)--were seat was originaly bolted---now empty .
HTH
   / Seat is too far back from wheel for me BX24 #9
HTH
invalid attachment
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
2018 Kia Soul Crossover SUV (A51694)
2018 Kia Soul...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
John Deere (A50322)
John Deere (A50322)
2007 International 4300 Box Truck, VIN # 1HTMMAAL07H360176 (A51572)
2007 International...
