Mowing Am i missing parts for my BX25 Mower
/ Am i missing parts for my BX25 Mower #1
Scooby074
Super Member
Nova Scotia
BX 25, ZD 326
Finally have a dry day and im trying to hook up my mower... But it appears i might be missing parts. Well a single part actually.
I have the rck54p-23bx deck.
I have the front "L-shaped" link, that goes from the deck to the frame of the tractor, but it appears that im missing the lever/bracket that locks this link in place. I assume im supposed to have on on a BX25? Ive seen some deck hook up videos online, but none featured the BX25... just other models in the BX series.
I dont have a manual for the deck and the factory tractor manual is pretty vague, and recommends seeing the deck specific manual. No help there:D
This is a brand new deck, never been installed so i have to level as well... not 100% sure on that either:laughing:
Its a holiday here, so my dealer is closed.. Id like to mow today while i have a break in the weather, so any info would help...
Please see attached picture. The "lever/bracket" in question is inside the yellow circle.
/ Am i missing parts for my BX25 Mower #2
I am thinking the the pin to lock the ladder shaped bracket is part of the bracket itself.It should be spring loaded if I recall correctly.What part of Nova Scotia are you from?I live near Windsor.
/ Am i missing parts for my BX25 Mower #3
I just took a few pictures of my BX2360 mower deck.It should be the same as yours.Hope this helps.
Thanks very much for the pics.
Looks like im missing a piece. I took the liberty of modifying your pic. The part that the arrow is pointing to is the part im missing.
The lawns going to be some high when i finally get it mowed as my dealer is 100mi away:eek:
/ Am i missing parts for my BX25 Mower #5
Although my deck was mounted when the dealer delivered it. I checked it out according to the "Rotary Mower" (code #K5381-7111-2) manual and must have spent about three hours adjusting and leveling it according to the manual. You better get it along with the missing part, especially since the dealer should have provided it to begin with. Best wishes up yonder.
/ Am i missing parts for my BX25 Mower #6
We have that pin, so I guess it's missing...
Thanks. Since the dealer is closed, i sent my salesman a email requesting both the missing part and the manual as both should have been included.
Only issue is the distance. Its going to be a matter of time before i can get there or they have a sales rep going my way to drop it off.
Why Kubota doesnt have their manuals and parts breakdowns publicly available (like deere for example) is beyond me... and beyond stupid in this age.
I did get a parts manual downloaded from Kubotabooks, but id sooner get it from Kubota's webste over some third party.
Picked up the bracket yesterday, however he didnt have my manual:mad: Im going to post a thread looking for a source of the manual online. Havent had any luck finding it for download on any of the regular sites
/ Am i missing parts for my BX25 Mower #9
Hopefully you will get the missing part. its shame they didnt include it, but anything is possible.
as for thee parts and manuals online- I agree it should be available directly from kubota. the closest thing to parts diagram is from messicks. you just go to their website and fill out your email address and request whatever diagram you want and bingo! you got a email copy diagram within 24 hrs.
Thanks RM.
Messicks is a godsend. Ive saved several of their breakdowns already. Got the parts and the deck installed, however im having cut issues. Frankly the cut is pretty bad.
The machine has lots of power (which is great) but the deck seems to be lacking suction. Im leaving pieces sticking up all over the place. I THINK it might be a setup issue, not sure though. So far, my old deere x540 was 10x the mower the BX is. Hopefully ill get it squared up and this first cut will be nothing but an anomaly.
/ Am i missing parts for my BX25 Mower #11
Thanks RM.
Are you mowing at full throttle as the manual recommends?
/ Am i missing parts for my BX25 Mower #12
Thanks RM.
ok, first thing first,, how is the blade installed? with wedge pointing down? did you level the deck before you mowed? leveling the deck will give you a great cut with engine rpms above 2800. manual says 3200rpms. how tall is thee grass before you tried cutting it?
Mowing at 3000. dont want to go to full throttle until the engine is a little more broken in. Currently at about 23h.
In fairness the grass was quite high, probably 6-8" in spots which is alot for a mulching deck. Im cutting at about 3.5". Yes the blades are on correct. that was the first thing i suspected.
I guess my issue is with lift. Seems like some of the grass flatttened by the front wheels isnt getting pulled up. This is particularly on the outside edges of the deck. Say the last 2" or so on each side. In the centre of the deck there appears to be lots of lift.
A member stepped up and has graciously offered me a scan of the manual. Hopefully once I have that i can give the level a final set. I just guistimated level and got it as close as i could. Part of the issue is i have nothing to go off that im sure is level (no concrete or pavement here)
Im going to give the BX the benefit of the doubt, but so far the Deere has it on quality of cut. I know (done it before) that the Deere could take the lawn from 8" to 3.5" with no stragglers. However the deere was not a mulching deck.
UNUSED FUTURE EQUIPMENT SEAT (A60432)
UNUSED FUTURE...
UNUSED FUTURE FTH100-(100)SHEETS OF GALVALUME (A60432)
UNUSED FUTURE...
7056CFL (A59228)
7056CFL (A59228)
2018 CATERPILLAR 305E2CR EXCAVATOR (A60429)
2018 CATERPILLAR...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A59905)
2019 INTERNATIONAL...
2016 Peterbilt 579 Wet Kit T/A Day Cab Truck Tractor (A59230)
2016 Peterbilt 579...
