stupidest welding question you have heard
   / stupidest welding question you have heard #61
I need to weld two oak boards together. Is it OK to use maple stick electrodes?
   / stupidest welding question you have heard #62
:laughing::laughing::laughing:
Yes, but use DC+ for more penetration. Especially if you have to weld over knots. :D
   / stupidest welding question you have heard #63
Sounds like mortise and tennon construction using maple dowels for tennon pins. Yep!! That will weld the boards together.
   / stupidest welding question you have heard #64
   / stupidest welding question you have heard #65
I've run out of electrodes. Can I just cut off some solder and use it to weld some steel with?
Or why pay all that money for electrodes when I have a bunch of steel wire and some flour laying around? Couldn't I just cut the wire down and dip it in a mixture of water and flour to form the flux?
:laughing:
Chad
   / stupidest welding question you have heard #66
... Couldn't I just cut the wire down and dip it in a mixture of water and flour to form the flux?
:laughing:
Chad
That sounds like the beginnings of a viral video hit.
   / stupidest welding question you have heard #67
:laughing:
Chad
No, but you could have rolled up wet newspaper, tightly against the rod, and used it for flux.
2008 CATERPILLAR M322D MOBILE EXCAVATOR (A51406)
2008 CATERPILLAR...
UNUSED MOWER KING SSFCAG Y HD HYD AUGER (A51248)
UNUSED MOWER KING...
2003 Acura Tl Sedan (A51694)
2003 Acura Tl...
Deere 325G (A50123)
Deere 325G (A50123)
Pair of New 700/40-225 Alliance Tires with Rims (A53473)
Pair of New...
RYOBI 2900 PSI GAS PRESSURE WASHER (A51248)
RYOBI 2900 PSI GAS...
