My 12" rankin auger sucks!!!
   / My 12" rankin auger sucks!!! #11
umm i cant get past 8" on my current 2 holes i have been working on. maybe ill take some vids
You can easily check the 3PH linkage adjustment I mentioned: Disconnect the auger from your two lift arms. Drop your 3PH until you're positive it's all the way down. Stand on one of the lift arms if needed to make sure it's all the way down. Make a little mark 9or use a little piece of tape) on one of the two 3PH cylinders, marking where the bottom is. Re-connect the auger to the lift arms. Try to drill a hole. When the auger stops drilling, look at the cylinder you marked ... If the 3PH is all the way down to the mark you made, then that's as deep as it can go the way you currently have your 3PH linkage adjusted. You'll need to adjust your 3PH linkage so the auger goes deeper when your 3PH is at the bottom of its travel.
One way is to move the lift arms' vertical linkage members to holes that are closer in to the tractor.
   / My 12" rankin auger sucks!!! #12
HEY BEPP !
If he gets his auger stuck maybe you can teach him how to get it out with out bending it ! :D
Wishing Ya the best ! ;)
Boone
   / My 12" rankin auger sucks!!! #14
EDIT: maybe i am missing something or doing this wrong, the only adjustment that i have is on the lower right hand 3pt arm where it connects the the hydraulic arms of the 3pt hitch, the top part of the auger just hooks up where the normal upper link would go and is hard mounted there is not adjustment.
Pictures of your setup would really help us help you. Do you have any adjustment holes on the boom itself like mine in my picture below? I have 7 different positions to choose from. Too far to one end will cause the auger to drag on the ground while driving and too far to the other end will cause the auger to not dig very deep.
I have only 2 holes for adjustment, the stupid thing is i have gotten it to dig a 36" hole before it just took me 20 mintues.
so i know it can go that deep, it just takes forever
   / My 12" rankin auger sucks!!! #16
Oh come on ... Surely the dealer would recognize if the thing is simply turning the wrong way?!?
"BINGO"
No such type gearbox said it to see who's paying attention. ;)
Just concerned bout safety !
Jokergerm post some pic's of process if you can,nice looking place btw. :thumbsup:
Boone
   / My 12" rankin auger sucks!!! #17
Perhaps the 3pt is moving too smoothly now for the bit to impact properly. Perhaps that jerkiness before was to improve the bit contact. :laughing:
I am very sorry for my comments above. :eek: They were below the belt and totally uncalled for............... I just couldn't resist myself! :drool:
"BINGO"
Boone
thats why i said WOW to the comment about it spinning the wrong way
ill go take some pics or a vid
i just took a 2 min video of what i call "Auger Fail"
it will be live in about ten min
   / My 12" rankin auger sucks!!! #20
:laughing: :thumbsup:
You might wanna use that line on tractor folks when they show up ! :D
Boone
2014 Ag Spray Schaben Sidedresser (A53473)
2014 Ag Spray...
2005 INTERNATIONAL 9400I TANDEM AXLE SLEEPER TRUCK (A54313)
2005 INTERNATIONAL...
GOODYEAR SET OF 9.5-24 AG TIRES (NEW) (A53473)
GOODYEAR SET OF...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
safety baskets (A53421)
safety baskets...
