Gas powered winch
   / Gas powered winch #1
rogdan
Gold Member
West Virginia
Farmtrac 360 DTC TLB
I picked up this little gas powed winch with the idea that I could use it for a few things around the farm. I'm looking for advice about putting it into use, such as what size cable, will it work without a fairlead, what kind of rating (pull) do you think I could get from it?
It looks solid and the old B&S engine runs but needs tuned, does anyone have a link about these older engines? Any idea what it was originally built for?
Thanks for any info/suggestions
   / Gas powered winch #3
I'd use 3/8" cable. For general farm use I'd think about mounting it on a carryall and that way you'd have your tractor weight to ground it. If you have a GN ball in your truck you could add an adapter to let it sit/hook on the ball. Something like a keyhole.
Good luck.
   / Gas powered winch #4
is it a Capstan winch?
   / Gas powered winch #5
   / Gas powered winch
Thanks for the ideas;
So 3/8 wire rope wouldn't be too large for the drum, I didn't think I could get by with larger than 3/16 like ATV winches? I thought about having a hook welded on the back so it could be anchored with a tree saver strap.
Intersting that it could be used like a capstan, I like having that option.
Would this winch likely or not have enough power to pull say 18" logs?
   / Gas powered winch #7
It is hard to tell how much pull it would have without knowing the amount of gear and pulley reductions. It looks like a gear reducer on the engine, pulleys and the winch combined would slow it down a good bit but we need numbers to say for sure.
   / Gas powered winch #8
Well looking at the engine I can say that is a3.5 to 5hp with the 6:1 gearbox I've taken enough apart to know. As for the sheaves can you get us some diameters? And a measurement of the spool. Then we can get a rough line speed and load rating.
   / Gas powered winch #9
The power of a winch can be multiplied with sheaves block & tackle style. I'd be more concerned with the strength of the winch frame/bearings/drum shaft. For 18" logs I'd anchor the load sheaves to something other than the winch frame so it would only see a fraction of the load. A 3:1 or 5:1 Z-system used in rope rescue would work well with your winch especially in the capstan mode.
Rope Rescue for Firefighting - Google Books MikeD74T
   / Gas powered winch
4" at the motor, 13" at the drum
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
Electric Golf Cart (A56859)
Electric Golf Cart...
84" HYD CURVED LOG GRAPPLE (A52706)
84" HYD CURVED LOG...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A57880)
2019 FREIGHTLINER...
2022 JOHN DEERE 624P WHEEL LOADER (A52707)
2022 JOHN DEERE...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A55315)
LIKE NEW 2023...
