My pole barn...a solo affair
   / My pole barn...a solo affair
Thats interesting you see 5 red squares....I see 9 squares, 5 red and 4 white.
RobertBrown,
Funny, Now I see 5 red squares in front of a polar bear in a snow storm.:rolleyes:
Brandi
   / My pole barn...a solo affair #212
RobertBrown,
Brandi
2 polar bears, one with a glass of milk, half empty....er a half full......ahhh maybe the glass is just too big;).
Robert,
I can't tell if you are flirting or trying to be a smart a%&.
Put the red siding on first and just make the white squares (4). Do the math and forget about 3x3. What ever it comes out too, make it symetrical.
What are the exact finish dimensions of the door? Is it longer than it is wide?
If youleft red on the bottom it will look fine.
RobertBrown,
I decided to draw a basic door with just 4 white squares like you suggested. Now, which one would pop out and say country to you?
Brandi
   / My pole barn...a solo affair #218
Brandi, The first one looks like a symbol for the White Cross.
Defiinitely the second one so that Purina can come to your place with a order to cease and detest from using their logo or be sued for infringement. LOL
Firefighter9208,Iowachild,Paguy,
Thanks. I agree. I just wanted to show Robert what 4 white squares looks like.
The 4 white squares do look like a cross.
The Purino logo also has a red border around the white that frames the 5 red squares. So I will not be infringing on a logo, only a reasonable facsimile.
hugs, Brandi
   / My pole barn...a solo affair #220
Hi all, I'm building a 16X24 pole barn with eight posts and four trusses. The question I have is how far apart do you put the purlins between the trusses. I want to use galvanized aluminum roofing.
12" centers will be stronger than 18". You have snow loads to consider and adding up the cost, it doesn't seem to be that much more.
I'm assuming you are talking about the prulins that will be on top of the trusses? You mentioned "in between".
I'm also assuming you are using 1x4 lumber as purlins
Auger Drill Bit (A56857)
Auger Drill Bit...
Steel Storage Cabinet w/Contents, 67" W x 24" D x 96" H (A59076)
Steel Storage...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
2025 Swict 66in Bucket Skid Steer Attachment (A56857)
2025 Swict 66in...
2000 Nabors 46ft. 40 Ton T/A Flatbed Equipment Trailer (A55973)
2000 Nabors 46ft...
BUSH HOG 14' ROTARY MOWER (A52708)
BUSH HOG 14'...
