Trailer Deck Protection Sikkens or Diesel/oil mix?
   / Trailer Deck Protection Sikkens or Diesel/oil mix? #1
RedNeckRacin
Elite Member
Western PA
John Deere 5083E MFWD, Kubota L3400 HST
Has anybody ever used the sikkens product before? I bought a gallon of it at $56 a gallon :shocked: I haven't even opened it yet. (still have the receipt!) I was considering the 1 part oil used diesel oil to 2 or 3 parts diesel fuel but Im wondering how slick it would be in the rain? (not rough cut lumber)
Any body ever try them both? Any ideas on how long either one lasts?
Thanks for the input guys.
   / Trailer Deck Protection Sikkens or Diesel/oil mix? #2
Take it back. No reason to spend money on preserving the already preserved trailer deck boards. About once per year I apply a diesel/oil mix but your proportions are way off. It's more like 10% diesel and 90% used engine oil. I do it mostly for looks. It is not slippery after it soaks in and/or gets rinsed by the rain.
Also, the drips that occur when applying heavily do not permanently kill the grass.
Recycling at its best.
   / Trailer Deck Protection Sikkens or Diesel/oil mix? #3
Sikkens or any varnish will degrade in UV light over time....even with the UV inhibitors.
   / Trailer Deck Protection Sikkens or Diesel/oil mix? #4
old/used oil is the best, I personally wouldn't waste hard earned $$$ on sikkens for a trailer.
I was just curious how long the oil/diesel mix lasts compared to the sikkens, I already bought the paint but its still in the can :thumbsup:. I was leaning towards the used oil but if its slippery I don't wanna make things any more fun than what they need to be!
   / Trailer Deck Protection Sikkens or Diesel/oil mix? #6
I use Sikkens on my decks, but don't think I can justify that cost on the trailer floor when I always have some used motor oil and a little diesel around. I don't figure The Evil One would stand for the used motor oil on the decks though.
   / Trailer Deck Protection Sikkens or Diesel/oil mix? #7
There are about 7 different types of Sikkens products, some made for deck surfaces, some made for vertical surfaces, some made for interior, some made for exterior. At the least you need to make sure you have the right product for your application.
Wrooster
Wrooster
I bought some of that Sikkens SRD if my memory serves me correctly, But I was reading the directions and it may need to be touched up every 2-3 years. I think the oil and diesel trick would be a much longer lasting and MUCH cheaper solution since I generate about 3 oil changes a year and at 3 gallons a whack I might as well get another use out of a $100 oil change.
   / Trailer Deck Protection Sikkens or Diesel/oil mix? #9
When I bought this house, there was a full, unopened can of Sikkens Cetol DEK in the garage, and I think that was what had been used on the patio in the past (12' x 22' with a 12' x 2' step at each end). At that time (Fall, 2005) I found a place that sold it for $50 a gallon. And I used that gallon to re-finish the patio. Now I thought that was really some good stuff. But when I wanted more of it, I couldn't find it. A place that I called said they had it, but it turned out to be the Sikkens SRD that they had. I applied some of it before reading all the fine print. It might be OK for unfinished wood, but applying it over the older finish took several days to dry enough to not be "tacky". The place did refund my money.
So then I tried Sherwin Williams Deckscape. Wow, what a difference. It's water based so much easier and quicker to clean up when finished, it lasts at least as long or longer than the oil based Sikkens, and it cost about $30 a gallon. It's also so much easier to apply. I've tried it with brush, roller, and on a fence with a paint spray gun.
Now I don't own any stock in Sherwin Williams, and am not trying to sell it, but I suspect it's all I'll use in the future. There may be something better, but if so, I don't know what it is.
Incidentally, I learned that Thompson's Water Seal is a Sherwin Williams company. The Sherwin Williams stores don't stock it, but can order it. I've used the old oil based Thompson's Water Seal with fair results. But then a neighbor and I used the new water based "Advanced" honey gold Thompson's on the fence between our places. That shown in the below photo is just over 2 years old and was applied with a rented paint spray rig. When I bought the little trailer in May of this year with the mesh floor, I bought a sheet of quarter inch plywood and applied some the old left over Thompson's Advanced Honey Gold to each side with a brush the day before I bolted it down in the trailer.
2016 Kenworth T880 Tri-Axle Brenner 4000 gallon Water Tanker Truck (A51692)
2016 Kenworth T880...
2019 Chevrolet Tahoe Multipurpose Vehicle (MPV) (A52377)
2019 Chevrolet...
2015 FORD F-250 SUPER DUTY (A53843)
2015 FORD F-250...
2015 Chrysler 200 Sedan (A53117)
2015 Chrysler 200...
2015 Ford F-550 4x4 Wrecker Tow Truck (A51692)
2015 Ford F-550...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A53472)
2016 Kawasaki 70...
