Landscape Rake width
   / Landscape Rake width #11
MtnViewRanch,
Thanks, I sent those guys an email. I found a company about 45 minutes away that carried Fred Cain but only had a 6' unit and did not know when they would place another order. They would not just order one rake for me, needed to be a certain size order.
Keep looking, and DO NOT go with the 6 footer, it is just too small for your machine. Stay with the 7 footer. Is Ken Sweet close to you? He carries Fred Cain implements also. The Land Pride units are good, but too much $$$$ for what you get in my opinion.
Just my :2cents:
Just my :2cents:
Ken Sweet is 2 hours north, not too bad of a drive if necessary. I wanted to look at a Landpride or a Woods this weekend but nobody has one in stock. It was disappointing but everything happens for a reason.
   / Landscape Rake width #13
Picked up a very used used and tweeked Leinbach 8 footer (from CL) for my GL3240 a few weeks ago. Ordered 10 replacement tines from AgriSupply for the 9 that were missing. Got a box each of grade 8 3/8-16x1.5 bolts, nuts & 2 boxes of washers.
Spent some quality time with it today, removing two jiggly & frozen hitch pins and untweeking one side of the L to which the tines are bolted. Grandpa's big old Stilson & a 5' piece of pipe for leverage did the trick after I broke what looks to be a pot metal casting on a comically huge HF pipe wrench. Eventual plan is to get an 8' section of 2x2 square tube to weld to the flange of the L to avoid repeating this effort. I strongly suggest looking for a rake with tines bolted to a closed section - much better torsional strength than an L or C channel.
Removing the hitch pins was the worst job I have attempted in a long time. Lots of Kroil, oil, torch, Kroil, oil, torch action with 3/4 drive breaker bar & 5' cheater pipe interludes. The folks over the hill could probably hear the shreiking of the threads. Should have cut them with the torch. Guess I am stubborn.
Didn't realize it was 8' when I picked it up - thought it was a 7. Not sure if I can spin it 180 degrees - I'll have to check that this evening. It really didn't want to spin at all. I found a grease fitting for the pivot while it was jacked up in the air that was still covered with original paint. I don't think the original owner(s) ever knew it was there or greased it. Spins nice and smooth, now. If I were to buy new that's something I'd look for - the grease fitting.
   / Landscape Rake width #14
Hitched it up tonight. With the 3pt adjusted just so, and the telescoping link ends fully extended, I can just sneak it past the R1 tires and spin it completely 'round. Didn't think it possible.
Baby Grand, Glad that worked out for you.
I ordered a 7' Fred Cain from Sweets yesterday. Hopefully they gave me a good price. I was tired of looking for one and just ordered it. Can't wait to get it.
   / Landscape Rake width #16
:cool: Be sure to let us know how you like it. :thumbsup:
Will do, got a call from them this morning. The rake should get to their place later this week and be turned around to me first of next week.
Got the rake on the tractor Saturday. Glad I went with the 7', not too wide straight and just right angled.
Straight
Angled
2020 DRAGON ESP...
167 (A52708)
167 (A52708)
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59228)
2006 iDrive...
48in Ditch Witch Harley Rake Mini Skid (A56436)
48in Ditch Witch...
Great Dane Van Trailer 1989 (A56436)
Great Dane Van...
