Chilly807
Elite Member
Something just occurred to me.. the teeth are supposed to be staggered across the two cutting edges. For instance, say each cutting edge has three possible locations for teeth, or four. One one edge, there will be a tooth at the outer edge, skip one spot going in toward the shaft, then another tooth. On the opposite edge, the outer spot will be left empty, the second one will have a tooth, and so on.
This way there is no "dead spot" in the cutting surfaces that will ride on the ground and keep the auger from digging.
Sean
Sean
