1st gen Toyota Tacoma question
   / 1st gen Toyota Tacoma question
I bought the truck used in '02, it's a '99. The PO had a set of 15x12 Mickey Thompson Classic IIs on it with some 325/60-15 BFG ATs. Meats. It'd catch a groove on the road or highway and I'd have to two hand the steering wheel to keep it straight. I road the ATs out and put some KMs on it, same size. It rode 100% better, but now you couldn't hold a conversation when driving. Rode that until the first of the year.
I've got these 33s on a set of Cragar Soft 8s that are 15x8. I can't remember the backspacing, but I had to put a 1/4" spacer up front to clear the calipers. I got them from DiscountTire online to my doorstep, mounted and balanced, for a little over $1000. It was more than I wanted to pay, but the warranty is outstanding and I definitely wanted a narrower wheel from now on.
Now, if you'll google "Tundra Brake Conversion" you'll find that you can direct bolt up a set of larger Tundra calipers using your Tacoma rotor. They're slightly larger and require a 16 or 17" wheel. It has a bigger piston and more brake pad. If you're interested. Had I found that first I would have gone with a larger wheel, but 15" tires are way cheaper anyway.
   / 1st gen Toyota Tacoma question #22
I was thinking MT classicII's. Not sure what im going to get. spacers are an option. Id like to keep it factory toyota if i can. I wonder what factory rim has the deepest offset in that bolt pattern? Probably not much different from the factory then what i currently run.
The black steelies I got were about $45 USD each. IIRC, the Mickeys run about $120. I think there are 2 variations of BS per wheel size. Summit and Jegs carry a good selection to get an idea. TTORA, IH8Mud, and ToyotaNation are decent forums with good data bases.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
WOODS DS8.50 LOT NUMBER 247 (A53084)
WOODS DS8.50 LOT...
2018 AMERICAN HAULER (A52576)
2018 AMERICAN...
2007 International 7600 Tandem Truck, VIN # 1HSWYAHR37J478209 (A51572)
2007 International...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
