Aaargh! 3-pt hitch not lifting any weight.
   / Aaargh! 3-pt hitch not lifting any weight. #1
project_X
Gold Member
Ottawa, ON, Canada
Kubota L235DT and L225
As you may have seen, I have added a set of rear remotes to my 1602D yanmar and everything has been tested; loader, 3pt hitch and remotes without any problems.
Symptoms:
Today, I was finally getting to moving some earth with my box blade, everything worked well raised/lower 3pt hitch on multiple passes. I used the loader and my toplink cylinder, no problems. All of a sudden my 3 pt hich would not lift my box blade. By setting the lift control to the highest up position, and moving the toplink out and in, I was able to get the blade off the ground and back to the shed.
I did not touch the control knob at all. I did check it after getting back to the shed, and it didn't have any effect on the raising.....
I removed the blade, lift would work with nothing on it.
I stood on the lift (180lbs on the lift arms), at 1500rpm they would hold position but not go up, at 2000rpm+ they would lift me.
Also standing on the lift, if I set the lift position to a high position and lowered the loader, it would raise the lift. using the toplink had no effect.
I checked the pressure into the IN port 3pt block, and it was 2000psi+ at 2000rpm or so.
The loader was able to lift the front of the tractor off the ground in the down position.
I then removed the loader from the circuit, it would not lift me unless it was at higher rpm.
I then removed the rear remotes from the circuit, so the only thing in the circuit is the 3pt hitch.
I checked the fluid level, it was good.
I assume the filters and pump are ok, if the loader and toplink cylinder can still
lift the tractor....
Possibilities:
Relief valve of 3pt hitch is not functioning properly (where do I connect a gauge to see the pressure?
Control Valve
Lift Cylinder
Anything else?
Here is a picture of the block under the seat
Any ideas? What should I try next?
Thanks,
Rob
   / Aaargh! 3-pt hitch not lifting any weight. #2
The knob under the seat is there to set the descent rate. If it is locked down, the 3pt cyl should not move. If it is binding, it may not move or move very little. You could take the assembly out and clean it and look for rust, debris, etc.
You can install the gage anywhere from the pump to the 3pt.
If you want to monitor the pressure in your tractor hyd system, install the gage in the IN port of the FEL valve. Then anytime you are using the hyd's, the pressure will be reflected on the gage.
Keep in mind, that pressure is only built up when a cyl or motor is doing work. Some work requires very little pressure.
If you max out the 3pt, or pull lever up fully, the 3pt relief valve should come on , and you can read the pressure on the gage. You can also remove the 3pt relief valve and inspect and clean, etc. It may be fixed or adjustable, just don't know.
Your manual might help some with the operation of the hyd system.
JJ,
I will mount a gauge on the in of the fel tomorrow to see the pressure.
I move the knob back and forth, but will clean it tomorrow as well.
What do you think might cause the 3pt to raise when I was lowering the FEL, but not move when it the loader was raising or bypassed? BTW: my loader is plumbed without a PB port (like a lot of the Yanmars).
Would a relief valve just stop working?
   / Aaargh! 3-pt hitch not lifting any weight. #4
Someone answer this question. If I raise the 3pt half up, and lock down the descent valve, it is not supposed to descend any lower, but can it still raise up with the 3pt lever, or does it close off the 3pt cyl?
From my understanding, the 3pt valve lets fluid into the cyl through a small port, and this port is where the descent valve is located. With the knob open, the fluid flows in and out the 3pt cyl via this port/orifice. There is also supposed to be a safety valve in the 3pt also.
Anybody have a better explanation, I would like to hear it.
Relief valve can quit anytime.
If your 3pt lever is not in neutral, it might raise.
If the 3pt lever is raised to much, the 3pt relief valve will relieve continuously.
Even if the valve is relieving, you might have some action, as the relief valve is relieving at about 2500 psi or whatever your system is set for. The relief valve can not get rid of the volume of fluid as fast as the pump is pumping.
Update:
I decided to change all my fluids, check screen (it was perfectly clean) and changed filter.
I remove the 3pt cylinder and all the seals look good. I cleaned the control valve with naptha, but everything looked clean.
I put everything back together. Filled with fluid and started everything up.
The lift functions the same, it can handle very little weight. If I stand on the lift arms, it will not raise me up (180lbs) until I increase the rpm. It will hold me if I stop it from raising.
Without the loader in the circuit, I put a pressure gauge on the output of the pump.
Pressure readings:
No valves engaged 0psi
remote valve (nothing connected) 2100psi
remote moving toplink out 450psi
remote moving toplink in 750psi
three pt hitch raising(nothing on the arms) 200psi
three pt hitch not raising(me on the arms 1500 rpm) 200psi
three pt hitch raising (2000 rpm, me on the arms) 450psi
the loader lifts with me standing on it.
I shimmed the relief valve to make it stronger, but it didn't have any effect.
I tested the flow, and my guesstimate, is that it was flowing about 5gpm (more than a gallon in 15 secs) at 1500 rpm.
I guess I will remove the rest of the relief valve to see if something is caught in it?
Any other ideas?
   / Aaargh! 3-pt hitch not lifting any weight. #7
J_J knows vastly more about this than me.
It seems like the fluid is bypassing the lift cylinder, but at high flow volume (High engine RPM) there is sufficient flow to "back up" the system, and allow the cylinder to lift. What confuses me is that you say it will hold weight once it has raised. I would expect, in my ignorance, that if there was a leaking relief valve that the system would immediately bleed down.
I read in your original build thread that you have the plumbing like this:
pump->loader valve in->loader valve out->plug diverts flow out of 3ph body (before it enters the valve)->
new valve in -> new valve out-> reservoir
----------------> new valve pb-> 3ph->reservoir.
When you say that you have removed the loader from the circuit, does that mean it runs pump to plug diverter, and the same from there out? What if you put it back to factory configuration on the plumbing? Perhaps that may isolate where the problem is. I'm pretty ignorant about this, but it "feels" like the problem is related to how the fluid is being diverted.
Also, PM sent.
Also, PM sent.
I put it back to the original state, but no change. I then put it back to the state with loader, remotes and 3pt valve, to have additional test points.
I removed everything from the relief valve, and it looks like there are only a few of parts (a lot less than the manual I have for a 226D.
lid
shims
spring
plunger
ball
everything looked fine.
but it still has the same problem.
is there another relief in the yanmar?
   / Aaargh! 3-pt hitch not lifting any weight. #10
There is one in the 3pt valve. Sounds like it is stuck open.
I looked at the safety relief valve, and it appears good, I increased the shims, and the system performed the same.
How do I rule out the lift cylinder (it holds weight without a problem)? If I can rule it out, my guess it is the control valve.....
   / Aaargh! 3-pt hitch not lifting any weight. #12
Maybe figure out a way to use a floorjack or something under the box blade to get it up into a raised position, with the height adjustment set to full on the three point. Close the lock valve, and see if it will hold the weight it won't lift.
That should allow you to isolate cylinder vs. valve for the fluid bypassing where you want it to be.
With the lock closed, you should be able to move the lift control up and reach bypass pressure-but make sure the pressure relief valve is in the circuit as you have things plumbed.
If it's in the circuit and you can't reach bypass pressure, I don't understand any way it could be something other than the relief valve. There is no other avenue for the fluid to return to the reservoir, and the pump functions correctly, since the loader will reach full pressure.
Now that I'm certain I have pressure and flow at every valve, I hav returned it stock; no loader, no remotes, no diverter plug.
The 3pt lift will hold the blade up, if I raise the blade manually.
Neither of the relief valves seem to relive anything, even if I close the knob down, I never get above 300psi at 1500rpm or 600psi at 2000rpm (and I'm standing on the arms).
Maybe a leak inside the control valve?
I only have the manual for a US version of the tractor, and the diagrams are poor (and different). I'll post in the yanmar forum to see if anyone has a breakdown of the control valve for my 1602 or similar Japanese model.....
   / Aaargh! 3-pt hitch not lifting any weight. #14
The fluid is going somewhere, though, since the pump will generate full pressure to the loader. If you aren't losing fluid, there must be a bypass somewhere.
Is there a pressure relief valve on the control valve in addition to one on the lift cylinder?
There are 2 pressure relief valves on the 1 on HP in and 1 at the knob (both on the lift cylinder)
I'm speculating that the flow that usually goes thru the "open center" to the tank when the valve is not moved is partially open when flow is sent to the cylinder, so some flow goes back to the tank. When the flow is high enough, enough flow is able to go to the cylinder and lift the arms.
Maybe my reasoning is incorrect, I'm a physicist, not a hydraulics expert by any means : )
   / Aaargh! 3-pt hitch not lifting any weight. #16
I think your idea makes a lot of sense, and would logically account for the symptoms you're having. I can't see any other possibility.
That's what I fear, I was hoping someone has another idea before I get in and tear it apart...
I have a positional 3pt hitch, when I raise the lever half way the arms raise unti they get half way. I think there is an arm with a spring that turns the valve to neutral, when it reaches position it is set for. I will take a look at this section, but I believe it is functioning correctly (unless there is an internal leak toi neutral when the lever is trying to make it go up...)
If the lever is set to half way, and I'm standing on the arms, no movement, if I get off, the arms move to half way.
   / Aaargh! 3-pt hitch not lifting any weight. #20
284 International,
I am not sure the 3pt can lift with the lock valve engaged. I haven't tried it. Do you know for sure with the valve screwed in tight with the 3pt half up, that you can raise the 3pt. I always thought the orifice that the knob screwed down, closed off the input and the output for the 3pt cyl.
I know the 3pt has a relief valve, but I have not seen the pressure relief settings for any 3pt. It could be equal to or lower than the FEL. It has to have it's own relief, as all tractors don't have loaders. There is also a safety relief, and I have never seen the pressure that will set it off.
The 3pt pressure can be checked by installing a gage in the pressure line anywhere from the 3pt valve to the pump. When you fully raise the 3pt, and it starts to bypass or relieve you can read the pressure. The normal pressure could be anywhere from very low pressure to 3pt relief pressure depending on load.
If the FEL takes all the fluid, you might not have any pressure at the 3pt for a short time.
2018 New Holland C227 Compact Track Loader (A61306)
2018 New Holland...
10 Lug Wheels Full Set (A57453)
10 Lug Wheels Full...
2023 VOLVO ECR25 ELECTRIC EXCAVATOR (A60429)
2023 VOLVO ECR25...
2022 JOHN DEERE 700L LGP CRAWLER DOZER (A60429)
2022 JOHN DEERE...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
