Any one try the JD SSQA other than RockGod?
   / Any one try the JD SSQA other than RockGod? #1
canoetrpr
Ontario, Canada
Kubota M7040 cab/hyd shuttle - current, Kubota L3400 - traded
I was surprised to hear the experience RockGod had with John Deere's SSQA adapter but I can't tell if it was the bucket he was using or or the adapter.
Just wondering if anyone else here is using or has used John Deere's own SSQA adapter with a SSQA bucket or other attachments.
   / Any one try the JD SSQA other than RockGod? #2
There's a member from Maine called Spudland dave I believe. He's all about the SSQA from what I've read of it. Rockgods is the first I've heard of the anyone having issues.
Matt
   / Any one try the JD SSQA other than RockGod? #3
Matt
Same here...
Is SSQA uncommon in the JD world ? It seems like a standard on most other tractors. What do the rest of you have ?
   / Any one try the JD SSQA other than RockGod? #5
Matt
I'd like to hear his take on this as well.
   / Any one try the JD SSQA other than RockGod? #6
This gap was w/workpro bucket.
The gap was even worse on my grapple. :mad:
RockGod, can you give me some context for looking at the picture. What is green and what is the black. Which gap are you referring to?
I have found that there are two welding establishments within driving distance who make the JD QA to SSQA adapter JD loader pins to SSQA adapters - Horst and Fluney welding. I have stuff from both and it is top notch. Really hard to believe that a company like JD can't get their adapter right! Unless I can get some more confidence though I will be going with one of their adapters.
   / Any one try the JD SSQA other than RockGod? #8
Hi,
OK, got it, Skid Steer Quick Attach! Half the night I thought everyone was talking about Sheep Safety Quality Assurance.....
Tom
   / Any one try the JD SSQA other than RockGod? #9
Sure, the green is the bottom of the JDSS adaptor (carrier). The black is the part of the bucket it sits into.
   / Any one try the JD SSQA other than RockGod? #10
As you can see, the gap between the ATI Tach-all and the grapple is much tighter!
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
SKID MOUNTED CONTAINMENT (A58214)
SKID MOUNTED...
2010 Kaufman Gooseneck Trailer (A59814)
2010 Kaufman...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A59823)
KNOW BEFORE YOU...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
2013 Ford F-450 Dump Truck (A59230)
2013 Ford F-450...
