Offset Box Blade?
   / Offset Box Blade? #1
PioneerMan
I need to grade my drive. There are trees on the sides, so I am thinking that unless some major trimming is conducted, my tractor will scrape the trees. It is a cab unit, I am actually more worried about the tractor than the trees. Is there an offset box blade, or should I get an offset blade? Suggestions?
Thanks
Tractor is a 4320 cut, and thinking about a 4 or 5 foot blade. I 'only' have to go about 1500 feet so I don't mind doing two passes.
   / Offset Box Blade? #2
Thanks
At some point in time the trees will have to be cut back. May as well do it now. Something I've learned in life "don't let trees dictate". I can show you a few things on my property where the previous owner did just that and it can make it plenty aggravating at times.
   / Offset Box Blade? #4
Thanks
Never seen or heard of an offset box blade. I think that you should be looking at either a 7' or 8' rear blade. JD rates the 4320 to use up to an 8' rear blade. Forget about the 4 or 5 foot blade. Waaaaaaaay to small for your tractor. I think that a good 7 or 8 footer with skid shoes would work best for you, other people may feel differently.
Just my :2cents:
   / Offset Box Blade? #5
This is solid advise. And the sooner you cut them the easier it will be.
   / Offset Box Blade?
Alright sounds good. I will start cutting. Thanks guys.
UNUSED DIGGIT 20'X30' METAL GARAGE CARPORT SHED (A54757)
UNUSED DIGGIT...
2017 KENWORTH T680 SLEEPER TRUCK (A54313)
2017 KENWORTH T680...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
UNUSED IRANCH 16" EXCAVATOR WOOD GRAPPLE (A54757)
UNUSED IRANCH 16"...
UNUSED RAYTREE RMBD72 - 72" HYD DRUM MULCHER (A54757)
UNUSED RAYTREE...
2024 JOHN DEERE 8R 280 LOT NUMBER 7 (A53084)
2024 JOHN DEERE 8R...
