Offset Box Blade?
/ Offset Box Blade? #1
PioneerMan
I need to grade my drive. There are trees on the sides, so I am thinking that unless some major trimming is conducted, my tractor will scrape the trees. It is a cab unit, I am actually more worried about the tractor than the trees. Is there an offset box blade, or should I get an offset blade? Suggestions?
Thanks
Tractor is a 4320 cut, and thinking about a 4 or 5 foot blade. I 'only' have to go about 1500 feet so I don't mind doing two passes.
/ Offset Box Blade? #2
Thanks
At some point in time the trees will have to be cut back. May as well do it now. Something I've learned in life "don't let trees dictate". I can show you a few things on my property where the previous owner did just that and it can make it plenty aggravating at times.
/ Offset Box Blade? #4
Thanks
Never seen or heard of an offset box blade. I think that you should be looking at either a 7' or 8' rear blade. JD rates the 4320 to use up to an 8' rear blade. Forget about the 4 or 5 foot blade. Waaaaaaaay to small for your tractor. I think that a good 7 or 8 footer with skid shoes would work best for you, other people may feel differently.
Just my :2cents:
/ Offset Box Blade? #5
This is solid advise. And the sooner you cut them the easier it will be.
/ Offset Box Blade?
Alright sounds good. I will start cutting. Thanks guys.
2018 DOOSAN G25WD0-T4F PORTABLE GENERATOR (A64281)
2018 DOOSAN...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A64280)
2001...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A59905)
1998 CHEVEROLET...
2013 CORPUS 40FT T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
