Offset Box Blade?
   / Offset Box Blade? #1
PioneerMan
I need to grade my drive. There are trees on the sides, so I am thinking that unless some major trimming is conducted, my tractor will scrape the trees. It is a cab unit, I am actually more worried about the tractor than the trees. Is there an offset box blade, or should I get an offset blade? Suggestions?
Thanks
Tractor is a 4320 cut, and thinking about a 4 or 5 foot blade. I 'only' have to go about 1500 feet so I don't mind doing two passes.
   / Offset Box Blade? #2
Thanks
At some point in time the trees will have to be cut back. May as well do it now. Something I've learned in life "don't let trees dictate". I can show you a few things on my property where the previous owner did just that and it can make it plenty aggravating at times.
   / Offset Box Blade? #4
Thanks
Never seen or heard of an offset box blade. I think that you should be looking at either a 7' or 8' rear blade. JD rates the 4320 to use up to an 8' rear blade. Forget about the 4 or 5 foot blade. Waaaaaaaay to small for your tractor. I think that a good 7 or 8 footer with skid shoes would work best for you, other people may feel differently.
Just my :2cents:
   / Offset Box Blade? #5
This is solid advise. And the sooner you cut them the easier it will be.
   / Offset Box Blade?
Alright sounds good. I will start cutting. Thanks guys.
2016 Ford Focus Sedan (A53424)
2016 Ford Focus...
2010 Hyundai Elantra Touring Sedan (A54815)
2010 Hyundai...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A51247)
2017 CASE IH 580...
UNUSED SWICT 78" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 78"...
23110 (A53424)
23110 (A53424)
