Aaargh! 3-pt hitch not lifting any weight.
   / Aaargh! 3-pt hitch not lifting any weight. #71
project_X,
Do you know the names of those parts.
I thought in an earlier post that you tore the valve down and cleaned and inspected everything.
I pulled all the pieces I could get out. The flow control valve has no head, I still can't figure out how to get it out....
Here it is.
you can't get at from the other side it is a blind hole, there are two plugs #20 that go in to that hole on an angle, but I can't get the flow control valve out.
   / Aaargh! 3-pt hitch not lifting any weight. #74
SWAG here... part #24 looks like a retaining ring? perhaps if you push in the assembly far enough you can get some kind of sleeve in there to compress #24? Sounds like a very special tool is needed if I'm right.
#24 is a P7 size o-ring
when the entire assembly is together, the plug can't come out as #15 and #13 hold into the block. you must be able to force it out from one of the angle holes, but I can't find a tool that is rigid enough and flexible enough.......
   / Aaargh! 3-pt hitch not lifting any weight. #76
What part # are you calling the flow control valve? If when it was all together did # 13 cover a little of that hole? By what I see from the parts brake down the packing ring is the only thing holding it in, unless something is in it locking # 8 up. I think you have to get air on the back side and blow out. The spring should of pushed it out, if #13 covers part of the hole holding it in.
By the way the # are from your picture not from JD's that we used before.
   / Aaargh! 3-pt hitch not lifting any weight. #77
I see we are writing at the same time. I'm on dialup so it's slow.
I agree that it should just come out, but whatever is sticking he valve is not letting me get it out.....
air inject from the spring side will leak around 8 and 9 and not force it out. i tried to stick an allen key in the hole in 8 and pulling. but an allen key small enough to fit in just bends....
   / Aaargh! 3-pt hitch not lifting any weight. #79
I see in one of the pictures you pushed the plug in. That should of came back out by the spring pressure unless it is a weak srping kink of looks like it is. Did that move easy when you pushed on it?
no, it was hard to push and doesn't come back to flush. i even reinstalled everything in the valve to try to get air to move it back out....
2025 YOU-380 Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attachments (A59225)
2025 YOU-380 Mini...
2020 Caterpillar 259D3 Compact Track Loader Skid Steer (A55973)
2020 Caterpillar...
2013 Yamaha Golf Cart (A57453)
2013 Yamaha Golf...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
2006 Ford F-450 4x4 Service Truck (A56858)
2006 Ford F-450...
CAT 350E2 Haul Truck (A55272)
CAT 350E2 Haul...
