Front-End Loader Worst things to do to a FEL
/ Worst things to do to a FEL #61
I'm glad some of you guys added some humor to this thread because after reading some of the advice given, I don't even know why some people have a FEL!
You can do many of the things listed as "not recommended" as long as you use some common sense.
Eventually, Darwinism will sort out those without the common sense :)
/ Worst things to do to a FEL #62
yup..and how else could i clean my windows if i didnt put the wife into the bucket and raise her up to clean them???? And now that i have a radio in the cab, i dont have to listen to her yelling at me to let her down LOL :p
/ Worst things to do to a FEL #63
I think using a FEL is just like everything else. Tell someone to use a maximum load of X and they will soon try 2X, just to see if they can get away with it. :confused2:
Gotta start somewhere.
/ Worst things to do to a FEL #64
:D:):laughing:
Now, that's funny right there. And true, too!
/ Worst things to do to a FEL #65
When dig out stumps and applying a lifting pressure the bucket slips off the stump with a might bang and potential damaging jolt. I now dig around the stump and push with great care. I use 2 wheel drive sometimes so I know how much pressure I am putting. In 2 wheel drive there is less chance of applying a breaking pressure when pushing
/ Worst things to do to a FEL #67
Don't throw a rope up and around a tree limb that is too big to pull down for with the FEL for easy cutting. The wife **** near had our 2320 vertical, she was looking up at the limb while dropping the bucket and did not realize the front of the tractor was coming off the ground instead of pulling the limb to the ground. She said she has seen me do it all the time, I told her not with that big of a limb.:thumbsup:
/ Worst things to do to a FEL #68
Sounds like you should be chaining the stump and using the drawbar rather than the FEL to actually displace the stump. Bucket is decent for digging at roots but every tractor has at lease two or three times as much pulling power than what the FEL can do.
/ Worst things to do to a FEL #69
I am not trying to start anything, but the comment about not digging with the FEL, gave me a chuckle. I dig all the time with my current Kubota, and did so with my smaller B7500 when I had it for 8 years.. The biggest digging job I did was with my old Long 2360 which was a 2WD tractor with loaded tires and ballast on the back.. I needed a large berm for my shooting range, so I took the top off of a hill I did not want. I probably dug at least 100 tons of dirt with the front end loader alone over a period of a month or so. The old Long had a Westendorf TA25 loader on it, and it worked quite well.
James K0UA
/ Worst things to do to a FEL #70
Please explain:confused:
/ Worst things to do to a FEL #71
Lift capacity with FEL is usually 500-2000 lbs. Yes you can push but the FEL bucket is not really designed to push against a narrow object (the tangent of contact between stump and bucket edge is typically 6-12 inches). The FEL arms are certainly not designed to push. It is a front end loader not front end dozer.
On the other end however we have a perfectly positioned drawbar engineered to take anything the tractor can dish out in pulling power.
My point, perhaps poorly expressed, was just that it is fine to dig out the roots of a big stump with the FEL but if the bucket is popping off while trying to displace the stump it means that stump would be better dealt with by wrapping a chain around it and pulling it out. My rough estimate was that a tractor can pull about three times what the FEL can lift.
Sorry for the confusion. Happy to debate stump strategy but I gathered from your post you didn't understand what I meant.
/ Worst things to do to a FEL #72
I thought that is what you were trying to get at. And I agree that the tractor can pull WAY more than it can lift.
BUT, the wording in your post in response to gaproperty read as if you could pull more than you could PUSH, not lift. Pull force would be the same (or nearly the same) as the push.
I push stumps out all the time. Some may argue that a chain and drawbar would be better, but the FEL is designed to push on things. Usually it is dirt, and not in just one location on the cutting edge, But I have found that my loader is stout enough to handle all the pushing force my tractor can deliver.:thumbsup:
/ Worst things to do to a FEL #73
I kinda agree. I do the same thing but with a grapple so I don't have the problem of the bucket suddenly popping off the stump and the forces are better distributed as I get the grapple underneath the stump rather than against it so I am not really pushing, I am lifting and pushing at the same time.
I know we all so it but it still seems reasonable to point out that CUT FELs are designed to lift more than push. Yes they dig but that is in relatively soft material and the force is broadly distributed across the bucket. If CUT FELs were really designed to withstand max pushing forces they would look exactly like bulldozers. Short, thick and oriented only forward.
My point was mostly that even in a discussion on FELs, and even though we all break the rule, we shouldn't forget that the drawbar is really the designed feature on a CUT for applying maximum horizontal force to a static load like a stump.
/ Worst things to do to a FEL #74
imo the fel is one of the most usefull versetal tools on a tractor.being over cautious in regaurds to the uses of the fel is a waste of a very usefull tool as long as respect for the machine is there when operating/and making choices of the approch taken to preform a task.scooping only loose material and polishing your bucket after each use is a joke to me.you can lift,scoop, dig,push,carry,level,fill on and on the lists of things you can do with it are only limited to your skill level/imagination and your feel for the hydralics.the dynamics of the fel are very simple the biggest things to watch for is the position of the tractor when handling loads on slopes,soft ground,slippery conditions,rough ground ect. always try to square up to your final target before fully lifting load so minimal turning is made with the load elevated.adjustments must be made to conditions at hand be safe and productive.be aware of your surrondings around the machine.everyone makes little mistakes to learn the tricks of the trade of loader work the secret is to not put your machine in a position to make big mistakes.biggest thing I see people doing wrong with fel's not knowing any better is driving the tractor around with the loader raised up higher than nessary or even see people driving fel all the way up there is no faster way to get yourself in trouble than doing this with or without a load.working road construction everyday this practice is just not seen unless your looking to get fired or kill someone so whenever i see someone doing this it makes my skin crawl knowing the potential danger.If i could only choose one tool to have on a tractor it would be a fel for me all the way.have fun,enjoy be safe.dont be afraid to work it! no polish nessesary;)
/ Worst things to do to a FEL #75
imo the fel is one of the most usefull versetal tools on a tractor.being over cautious in regaurds to the uses of the fel is a waste of a very usefull tool as long as respect for the machine is there when operating/and choices of the approch taken to preform a task scooping only loose material and polishing your bucket after each use is a joke to me.you can lift,scoop, dig,push,carry,level,fill on and on the lists of things you can do with it are only limited to your skill level/imagination and your feel for the hydralics.the dynamics of the fel are very simple the biggest things to watch for is the position of the tractor when handling loads on slopes,soft ground,slippery conditions,rough ground ect. always try to square up to your final target before fully lifting load so minimal turning is made with the load elevated.adjustments must be made to conditions at hand be safe and productive.be aware of your surrondings around the machine.everyone makes little mistakes to learn the tricks of the trade of loader work the secret is to not put your machine in a position to make big mistakes.biggest thing I see people doing wrong with fel's not knowing any better is driving the tractor around with the loader raised up higher than nessary or even see people driving fel all the way up there is no faster way to get yourself in trouble than doing this with or without a load.working road consruction everyday this practice is just not seen unless your looking to get fired or kill someone so whenever i see someone doing this it makes my skin crawl knowing the potential danger.If i could only choose one tool to have on a tractor it would be a fel for me all the way.have fun,enjoy be safe.dont be afraid to work it! no polish nessesary;)
+1,:thumbsup:
Well Said.
James K0UA
/ Worst things to do to a FEL #76
Throwing a single chain around the middle of your front loader bucket can collapse the bucket when picking very heavy object. Very hard to reverse this process.
/ Worst things to do to a FEL #77
Also remember if you put something in your bucket like chains, chainsaw etc and forget about them when you start digging into a pile of gravel. I know many people whom have done this... :eek:
Glad to know this , I thought I might be the only person that buried a shovel
under 3 loads of dirt. <Grin>
/ Worst things to do to a FEL #78
Anything that compromises the structural integrity of the FEL and the tractor thus stretching the capabilities in regards to safety issues and jeopardizing the welfare of the operator is, in my opinion, wrong. All of us probably have tried various unsafe methods with our FEL, but hopefully this thread and subsequent posts will serve as a reminder that there exists a "wrong way" and the "right way". Everyone have a safe and productive "seat time". :tractor:
/ Worst things to do to a FEL #79
Agreed. I sould probabally use the drawbar more than I do, But I usually find it just easier to push. That way , if I cant quite get it out, I dont have to jump off, unchain, turn back around, and dig some more. If I cannot push it out, I just continue digging.
Plus, I usually have the bushhog or heavy blade on the back, making it a PITA to get the the drawbar to hook a chain up.
But I guess that is the beauty of being an experienced operator and owning my tractor. Because I know the risks involved, and how to minimize them, as well as knowing the limits of my machine. If I break something, I will fix it and move on:thumbsup:
/ Worst things to do to a FEL #80
Yep. Making the drawbar available is one of the best reasons for using a dedicated weight box on the 3pt instead of depending on a bulky implement. One of these days I might even get around to building one.
2014 Ford F-550 (A55973)
2014 Ford F-550...
pressure washer, and trailer (A56859)
pressure washer...
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2018 INTERNATIONAL...
2007 International Derrick Digger Truck (A60352)
2007 International...
2013 Chevrolet Impala Limited Sedan (A59231)
2013 Chevrolet...
