Auto Darkening Lens Reaction Time
   / Auto Darkening Lens Reaction Time #52
Interesting... Im a "john Lennon" goggle wearer myself. (the ones with the individual eyecups)
I wear glasses.. so gogles are a PITA.. the face shield in shade 5 is great for gas torch cutting for me.
can't believe I waited so long to get one.
and yes to the prev poster. I do like the fact that the AD helmets are uv protected even if not dark.
very comforting for sure!
soundguy
   / Auto Darkening Lens Reaction Time #53
You realize that most AD helmets are shade 5 when off? At least the Speedglass are for sure, but I think that is common. So you can just turn off your helmet and essentially get a cutting torch face shield for free. If you leave it on the sparks will trigger the lens and will drive you nutz. BTDT.
   / Auto Darkening Lens Reaction Time #54
yep, but i like the freedom of movement that goes with goggles over the helmet. Plus my helmet at shade 5 is more yellow tint then sexy green:laughing::thumbsup:
And my lens is auto on... so i physically have to go in and turn the small sensitivity pot to set it to grind.. too much work with gloves on/
Too bad a company wouldnt make a AD helmet where you can just touch a special part of the lens exterior and flip it between modes, shades and sensitivity.. Having a Heads up display inside the helmet would visibly show you your settings... just a thought.. with the price of the high end helmets, features like this couldnt be that hard to incorporate... now where's my royality check:thumbsup:
   / Auto Darkening Lens Reaction Time #55
another reason I like a face shield over gogles is.. well.. sparks and slag NOT hitting my face.. :)
soundguy
   / Auto Darkening Lens Reaction Time #56
soundguy
I agree. Full face shield is only way to go, especially in welding up while lying on the ground as i always seem to be stuck doing.
   / Auto Darkening Lens Reaction Time #57
yep.. I rarely am in a position where I like to be when welding. nothing 'easy' to reach seems to break.. :)
soundguy
   / Auto Darkening Lens Reaction Time #58
soundguy
Yup.. and at the most inopportune times. I just broke 2 tines off of my rototiller.....now that is going to be an interesting weld. Gots to try it, and if it doesn't work, then ill order a few replacements.
   / Auto Darkening Lens Reaction Time #59
hopefully not a spring steel.
   / Auto Darkening Lens Reaction Time #60
MORBARK 6400XT WOODHOG HORIZONTAL GRINDER (A60429)
MORBARK 6400XT...
Westfield Conveyor (A56438)
Westfield Conveyor...
LEEBOY 8510 ASPHALT PAVER (A60429)
LEEBOY 8510...
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
