trailer hitch ball on drawbear or not??
   / trailer hitch ball on drawbear or not?? #1
kubota4me
USA
An orange one
When dragging trees with a chain hitched to your drawbar, is it preferrable to have a trailer hitch ball bolted to the drawbear in which to wrap the chain around to avoid the chain sliding back and forth?
   / trailer hitch ball on drawbear or not?? #2
yes id put a knob on the drawbar,an then like you say you could wrapp the chain around it.
   / trailer hitch ball on drawbear or not?? #3
I use a clevis.
   / trailer hitch ball on drawbear or not?? #4
I use a clevis.
X2
A clevis is the best option and also probably the safest. Depending on the size of your tractor, a hitch ball can actually shear off at the base if pulled on too hard (especially if you ever have to yank on something.)
   / trailer hitch ball on drawbear or not?? #5
When I do that, I use a shackle, at least thats what we call them in the Rigging trade up here, clevis=shackle, same, same.
DevilDog
   / trailer hitch ball on drawbear or not?? #6
I use a clevis.
X2
DevilDog
x3 or is it x4 now:thumbsup:
I dont use the ball becasue I have a couple that have been ruined by doing this. The chain mars up and chips the chrome plating.
   / trailer hitch ball on drawbear or not?? #7
   / trailer hitch ball on drawbear or not?? #8
I prefer the clevis/shackle, but you could use the time honored trailer ball, just know you will booger it up, possibly over stress it. I wouldn't use that ball on a decent trailer coupler.
In a bind, those trusty old balls have come to the aid of many a stuck vehicle.
JB
   / trailer hitch ball on drawbear or not?? #9
I wouldn't recommend pulling from the "drawbar" ( I assume you're calling the 2 foot long steel bar that goes in the 3 point lift arm ends a drawbar?) at all, if you have the option of using what Kubota calls a "drawbar" mounted solidly under the tractor.
I grew up calling the 2 foot long bar a "drawbar", just like everybody else in the civilized world. I've since been edumacated as to think that I should be pulling from the Kubota version of the drawbar whenever possible. Less chance of a flip-over and a solid mounting. We just loop a chain over the ball I have mounted on it and pull from there. It's not good for the ball, I may end up welding a T on the end of it and using an anchor shackle on one leg of the T and a ball on the other for pulling a trailer around.
Sean
   / trailer hitch ball on drawbear or not?? #10
I wouldn't recommend pulling from the "draw bar" ( I assume you're calling the 2 foot long steel bar that goes in the 3 point lift arm ends a draw bar?) at all, if you have the option of using what Kubota calls a "draw bar" mounted solidly under the tractor.
Sean
I think most folks referring to the draw bar were writing about the bar underneath the rear axle...not the 3PH type.
John Deere 9450 Combine (A50514)
John Deere 9450...
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
2006 Poly-Coat Tanker Trailer (A50774)
2006 Poly-Coat...
SpotWeld RockerRite 480V Arm Type Spot Welder (A50322)
SpotWeld...
SET OF HANG-ON PALLET FORKS (A51243)
SET OF HANG-ON...
Chevy Car (RUNS)(TITLE) (A50774)
Chevy Car...
