What size would be the largest recommended rear blade for this tractor. I am eyeballing a 7' blade @ Tractor Supply for $369.
CountyLine Rear Blade, 7 ft. - 2130047 | Tractor Supply Company
Congratulations on the L3700, did you buy new or used? Did you end up with a cab? What happened to the DK40 cab you had mentioned?
As far as the rear blade goes, it's going to be a challenge for you. I clear my 100' X 26' driveway + 100' X 12' round about as well as my 100' X 65' rink. I live in Ottawa and we get a lot of snow, but there's no lake effect around here. I'd say your driveway will be a piece of cake, it's the 200' X 300' parking lot that's going to give you a headache. You're going to have to make relief cuts before trying to plow with a rear blade. Once you get too much snow pushed to the side, the tractor really starts to get pulled around. Here's a video that shows a Kubota trying to plow a small parking lot, you'll see what I mean.
How To Series - Snow Removal - Tractor Rear Scrape Blade - YouTube
With my JD 955 last winter (almost 1900 lbs + JDP Cab + loader, R4 tires not loaded and 6ft rear blade) I was able to do a pretty good job on the driveway, only having issues by the edge of the driveway (pushing snow 26ft always to the same side) in heavy snow. On the rink, I cut it in two and ended up having to cut relief lines using the loader in heavy snow. There was no way the rear blade could handle that much snow. I'm expecting my Kioti CK 30 (3042lbs + 800lbs loaded tires + loader) to be able to handle the driveway with ease and be much better on the rink. According to TractorData.com, your
L3700SU is 2568lbs + Loader. That make you a little lighter than my JD 955 cab, which is why I'm thinking a 300' X 200' parking lot is too much for a rear blade.
The fasted option would be a front snow box. That's what most of the guys use here in Ottawa for parking lots, although it's usually with a front end loader or backhoe. I still think the best option for moving lots of snow, especially for a lighter, higher powered CUT, is with a snow blower.
When my wife finally let's me out of the dog house, I'm going to get an inversed 68" snow blower. You keep the FEL, drive forward and can get right up to the house or garage. If money just doesn't allow anything else, I'd get the 7 ft blade. You'll be using your FEL quite a bit anyway so I wouldn't worry about a little extra drag on the tractor.
