Landpride RBT 4096
   / Landpride RBT 4096 #1
Furu
I am looking at a used Landpride RBT4096 rear blade. Haven't seen it yet but will look at this coming week. It has two hydraulic cylinders on it, offset and tilt, manual only on the angle. It reportedly has end plates and skid shoes as well. Firm price is $2550 . Consignment dealer says that it has been lowered once and he has tried to get it lowered again but the guy will not budge.
I was really looking at all hydraulic but that could be added later for the angle.
I have a JD 4720 58 HP. I had been looking at the RBT3596 rated 35-80 HP.
The RBT4096 is rated 65-100 HP, which is a bit above my 58 HP. The moldboard is the same length and height on both units. The weight according to the literature is conflicting either 6 lbs lighter (which makes no sense) for the RBT4096 vs RBT3596 or is 19 lbs heaver for the 4096 vs 3596. Either way I don't see much difference that would effect me. I suspect the 40 series rating may come from the 40 series having a 108" moldboard option that would require the extra HP. The unit new without the endplates but with three hyd cylinders is quoted at $3412.
My questions are:
1. Does anyone have a feel as to the price ($2550) being good for a three year old supposedly "lightly used" RBT4096? (have not seen it yet)
2. Does the 65 hp min rating say, stay away for me and my 58 hp machine even though the moldboard is the same and the weight is plus or minus 6-19 lbs different?
Any inputs are welcome. Thanks
   / Landpride RBT 4096 #2
That is a fair price. The additional cylinder and hoses will end up costing you a few hundred $. If it is in great shape it is a deal, if not, then you are still saving some money, but you are getting a used implement that has been worked hard??? I wouldn't worry about running it behind your tractor, it will be fine. Land Pride has some very nice rear blades. :thumbsup:
Got a little more information. The cutting edge has never even been turned over. Looking forward to seeing it tomorrow to see what it looks like.
   / Landpride RBT 4096 #4
Maybe get some pictures and post them. I am curious as to the condition it actually is in. I have a LP RBT45108 and am wanting an RBT3584 for my smaller tractor. Others on TBN have gotten very good deals on these types of blades.
   / Landpride RBT 4096 #5
Don't know your plans for it, but you'd definately have enough for your tractor. The weight is going to add up when you add 2 hydraulic cylinders, the end plates and the skid pads vs. the 35 series. I see a new 4096 on tractorhouse w/o the cylinders, end plates and pads for $2K. FYI, you can find 3596's around for about 1/2 that if you can get along with one
If you can find a RBT3596 for 1/2 that I would love to know where. The RB3596 you can find for 1400 new (so 1/2) but not the RBT3596.
Well I took a look at the RBT4096. The salesman that I had talked to was not there as he had said he would be so I talked to another guy. He told me that they also had a new RBT3596. Went out and took a look at the 3596 and it had two cylinders, manual on the offset. Then looked at the RBT4096 and instead of only the two cylinders (no offset) that I had been told originally, it had all three cylinders. (Surprise) What I wanted anyway. They told me the new RBT3596 with two cylinders was $2550 and the RBT4096 with three cylinders was $2400 firm since it was a consignment sale. Of course the first person on the phone told me $2550 firm due to consignment and only two cylinders so who knows. I think he may have been confused. Anyway they came down on the RBT3596 to $2300 but said they could not move the price on the 4096. It would have cost me another about $350 to add the third cylinder and hose and fittings so I took the more capable and better priced used unit, at $2400 which also included skid shoes and end plates (one of which still had the factory paint, he never put it on just used one) which the 3596 did not have. A $3800 unit new for $2400 with minimal usage.
Very happy with it. Not much wear. The cutting edge does not even have a nick. The moldboard does have some rust but just because the paint got rubbed off. It has been left out in the weather and has some minor pock rust on the frame.
Never dealt with this dealer before but really liked them. Had lots of inventory. They are what my normal dealer was before they went through two different owners. Just wish they were not 2+ hours away in good traffic and 3+ in busy traffic
The pictures you asked for were as I unloaded it and then after hook up. It was a pretty good deal I think.
   / Landpride RBT 4096 #8
Thank you for posting the pictures. You got yourself a very nice blade for a good price. :thumbsup: Very annoying when you talk to someone on the phone and get one story and then go in person and get another. At least it worked out for the better for you. :cool2: Now all you need is a hydraulic top link so that you can really pick that blade up for transport.
I sure would like to come across a deal like you got on an RBT3584. Oh well, someday. :drool:
I forgot to mention that I decided to drain the hydraulic fluid out of the lines and cylinders since I did not know what condition the fluid was in and did not want to contaminate my system. I am not due for a hydraulic change for another 140 hours and did not want to take the chance.
Well the fluid out of the hoses was pretty clean but when I flushed the cylinders discolored fluid and lots of sediment came out. I guess with a closed end cylinder stuff accumulates. It probably would not make it back out into the main flow line but why take the chance.
   / Landpride RBT 4096 #10
You did good on your purchase, and those end plates will make your life easier when it comes controlling where the spoils go.
Just make sure to raise the parking stand before doing any work! Don't ask me how I know.
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
2025 New/Unused Wolverine Hydraulic Skid Steer Pallet Forks (A51573)
2025 New/Unused...
2020 Chevrolet Tahoe SUV (A51694)
2020 Chevrolet...
2018 SkyJack SJ1056TH 4x4 Rough Terrain Telehandler (A52377)
2018 SkyJack...
2016 John Deere 5055E 55HP Utility Tractor (A52377)
2016 John Deere...
