Bedder/hiller fabrication
   / Bedder/hiller fabrication #21
Modn,
I'm not sure, I'd have to see it but it seems like the tires would compress the ground and reduce the effectiveness of the outer discs.
Rob
You may have a point....
   / Bedder/hiller fabrication #22
I'm trying to figure out how that would work. What's your rear tractor width?
I guess you'd have to have one hill outside the tires and off to one side?
Rob
Not sure if anyone mentioned this but the way I used to hill potatoes and make narrower and "multiple-looking" space saving rows is to do one row with the hiller centered on the tractor. Then do the next row with the tractor tires in the tracks formerly made on the first pass. It narrows the rows and both passes are in clean soil.
Another way I have made narrower (and space saving) rows is to offset the hillers on the tractor and then make one row and then reverse at the end of the row and come back in the tracks that give you a narrower row. This makes the row even narrower. You leave your tire track as the center between the rows. It's a variable depending on how wide the hillers are set up.
Multiple units have not worked for me.
That's interesting, I had thought about using my potato digger but couldn't see the double row it made so close together working. I will try it however and thanks for the advice.
I did get the two discs I ordered from AGC and was surprised to see that they had ball bearing hubs. I'm going to get everything set up and weld it together but that probably won't be until spring as we have wood to get in for the winter now that the gardens are bedded down.
I'm really looking forward to next spring and Nancy has already ordered seeds! With world seed control going the way it is organics are getting harder to find.
Rob
   / Bedder/hiller fabrication #25
That's interesting, I had thought about using my potato digger but couldn't see the double row it made so close together working. I will try it however and thanks for the advice....
...Rob
Good ideas here. Go back in the thread and click on the link (here you go) of
http://www.tractorbynet.com/forums/build-yourself/200795-my-low-buck-potato-hiller.html
how I built --photos too--my hiller out of various parts. Good hillers/diggers need to be simple, rugged, easily adjustable and able to tolerate twisting and abuse, especially if you dig potatoes with them. I also dig carrots, flower bulbs, beets and sometimes ridge the garden for winter with mine. In the spring , I could plant on the remaining ridge since the water lays in the trench and the ridge warms up quickly. I use a much smaller shovel to make small rows in the spring for bulbs or things needing a trench. Sure beats a hoe.
One of the aspects of the way I built mine is that I could "double up" on the row and have one set of hillers low in the row and a second right behind it to really hill up the potatoes or make a bigger/taller hill or whatever. I haven't needed to yet but I could. The second set doesn't have be round disk but the "sweeps" ("buzzard"? or "lay-by"?sweeps) that Agri Supply also sells. I have some if anyone wants a photo.
Afer you build whatever, mark the positions so you can remember where you started in the spring and the adjustments along the way. Then the next year is five minute setup.
Just my two cents here.
   / Bedder/hiller fabrication #26
For growing garlic in raised beds I added "wings to each side of my tiller... I wanted to show the entire set up but my camera bit the dust... Anyway there is a wing on each side of the tiller and the bed is elevated about 8". The soil is really fluffy and drains well... the top "flat" of the raised bed is about 36" wide and the wings bring the soil inward about 8" on each side... Hope this gives another "food for thought" idea... Dave
   / Bedder/hiller fabrication #27
I like it. Simple enough that I could make it from scrap.
   / Bedder/hiller fabrication #28
Baby Grand, mornin'... One more point.. My tiller is wider than the inside width of the tires... So, the bottom edge of the wings, when installed on the tiller, is narrower than the tire inside width... This allows to drive the tractor down the raised bed again for any other work that needs to be done... The upper edge of the wings is tapered inward so the dirt won't slough off, back into the tire track... Also I have added a drag of sorts, that attached to the door on the tiller, to "pre groove" the raised bed for planting purposes... that works well also..
Thanks for all the great ideas guys!
When I till I usually run back and forth several times and I'm wondering how the wings would affect that?
Rob
   / Bedder/hiller fabrication #30
Mornin', Dave! My tiller is just a skoatch (less than a tad) narrower than my tires (ags) outside-to-outside, so I think this would work for me if I can shove enough soil to the center that I have 2 clear tire tracks. I'm thinking of adding a toolbar on two receiver hitches to take a pair of hilling discs, but I could also add the hilling wings with a hinged leveling plate across the top of both wings, just aft of the discs, to get a nice shape and a little consolidation to the bed. Attaching at the tiller skids, as you did, would give me a nice 4 point mounting, which should be plenty tough. Time to get out the shirt board and hot glue and see what that would look like. Thanks for this idea!
-Jim
2024 CATERPILLAR 242D3 SKID STEER (A52705)
2024 CATERPILLAR...
JOHN DEERE 1725 CCS (A53084)
JOHN DEERE 1725...
TORO TRX-20 WALK BEHIND TRENCHER (A51406)
TORO TRX-20 WALK...
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
2010 International 4300 2,000 Gallon Water Truck (A52377)
2010 International...
