Looking for fisher snowplow adapter
   / Looking for fisher snowplow adapter #11
I like how you have the plow mounted under the loader. Just about ready to start building the loader atachment For a Dk 55 Koiti with a fisher plow.
Just started to snow today so I better hurry.
Just started mine today also. I bought mine with mounts on the front of the QA adapter plate but am changing to a rear mount so the plow doesn't stick out so far. I was able to move it back about 14" behind the plate. I'll post some pics if I finish it this weekend.
Here's a pic before mods
Jeff
   / Looking for fisher snowplow adapter #12
Hi.
Any problem getting the Quickatach to work if the plowframe is mounted under it?
   / Looking for fisher snowplow adapter #13
Hi.
No problem at all. I just finished welding it up and it goes on and off easy. I just have to paint and I'll be ready for snow.
Jeff
   / Looking for fisher snowplow adapter #14
Some more pics. With the bar on the loader I had to drop it down 5" and then back 15". I could have gone back more and still have full angle but I was worried thar would stress it too much. That bar makes it harder.
Jeff
   / Looking for fisher snowplow adapter #15
I also made a ballast barrel. It has a receiver hitch and a place for a chainsaw scabbard. I left the concrete 4" so I can put gas and oil and chains on top. Also put in plastic pipe for shovels,rakes or whatever. Should make the plowing easier.
Jeff
   / Looking for fisher snowplow adapter #16
Thanks for the pictures.I have a woods loader but it has the same bar and the handles are the same for the quickdisconect. So the pictures you sent will help. I almost got the quickdisconect plat done then I can start on the plow mount.
   / Looking for fisher snowplow adapter #17
Just finished my atachment today. How do you add Photo ?
(INOPERABLE) DYNAPAC DOUBLE DRUM ROLLER (A58214)
(INOPERABLE)...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A56438)
Ditch Witch 6510A...
2016 Ford F-550 Venturo HT40KXX 3 Ton Crane Mechanics Truck (A59230)
2016 Ford F-550...
BOBCAT T300 SKID STEER (A60429)
BOBCAT T300 SKID...
Bobcat T590 (A60462)
1968 Oliver Model 1950 2WD Tractor (A56438)
1968 Oliver Model...
