Cleaning exhaust build up on FEL arms??
   / Cleaning exhaust build up on FEL arms?? #21
I added a 1 1/4" copper, 45 deg. sweat street elbow. (pointed down)
Cut two slots 180 deg. apart, and the width of a hose clamp, in the end of the copper fitting that fits over the tractor exhaust. (slots let it compress a little when the hose clamp is tightened. It's a snug fit anyway)
I was going to weld a fitting on, but I wanted to try one anyone could do that doesn't weld.
It works great, all the exhaust goes to the ground now.
Great idea! Works very well. Thank you.
   / Cleaning exhaust build up on FEL arms?? #22
I made a turn down for my 3240 exhaust which works well in the winter but I take it off in the summer because it stirs up too much dust.The dust is close to the air filter intake so I don't think that is a good thing.A vertical exhaust stack would be much better I think but I haven't gotten around to it yet,maybe some day.
   / Cleaning exhaust build up on FEL arms?? #23
I turned mine down and ran it back by the rear wheel... I have no idea why Kubota builds such a nice piece of equipment then can't add a few more feet of pipe to finish it off right.
   / Cleaning exhaust build up on FEL arms?? #24
Mine is similar but I just heated mine for the B3030. It expanded the metal and I slipped it over the pipe. When it cooled it was very snug.
   / Cleaning exhaust build up on FEL arms?? #25
Dawn dishsoap work quite well also
   / Cleaning exhaust build up on FEL arms?? #26
Any chance hot exhaust discharge directed downward at ground under brush when cause afire if tractor was left running in one spot ? I have no idea hoe hot exhaust gases are .
   / Cleaning exhaust build up on FEL arms?? #27
The tip of the exhaust pipe sits pretty high off the ground. I guess anything is possible if you let a tractor sit for quite a while in some very dry grasses/weeds/etc. I don't have high grass/weeds/etc. and never sit idle in one spot for very long.
   / Cleaning exhaust build up on FEL arms?? #28
You might try applying fluid film when it is clean, then it will not stick.
   / Cleaning exhaust build up on FEL arms?? #29
having had a tractor with a vertical stack for 20 years I consider the way my L4240's exhaust is routed an improvement. The vertical stack would allow rainwater to get into the exhaust manifold unless I put a coffee can on it. if I forgot, then the next time I started the tractor a rain of crap from the exhaust pipe would shoot up in the air and cover me with little black spots. Not to mention how vulnerable it was sticking up when i was working around tree limbs.
Frankly the soot on my FEL arms are the least of my concerns...my tractor stays pretty filthy most of the year, even if I pressure wash it.
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A53843)
RIPPER ATTACHMENT...
2008 Ford F-550 Reading Enclosed Service Truck (A52377)
2008 Ford F-550...
2005 MACK CV713 (A53843)
2005 MACK CV713...
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
2016 Ford F-450 12FT Flatbed Truck (A51692)
2016 Ford F-450...
2023 Club Car Carryall 700 Utility Cart (A54811)
2023 Club Car...
