Ford 1700 clutch adjustment
   / Ford 1700 clutch adjustment #51
I've pulled the bearing and carrier off. The bearing felt dry and a little gritty, but not bad. It should be replaced, but it wasn't on the verge of failing, either. I'll measure and post photographs of the springs, probably tomorrow afternoon, when I get some time. I can't figure out why the pressure plate was so cockeyed, though.
My starter is supposed to have shipped today. There's a local place that may be able to provide the clutch parts. I'm going to talk to them tomorrow. I'm hoping to take advantage of the Thanksgiving holiday and get it up and operational then. Thanks again for the help.
Cool:thumbsup: It all pays off when you get them all done and ready to go. You'll be very happy for your 1700. it is a great little mule:D
JC,
ps. How about the Pilot bearing. You need to replace that too. Did the splines on input shaft look okay?
I've got new pilot and throwout bearings, a new friction plate, and a rebuilt pressure plate now, along with an alignment tool. The splines on the input shaft looked good. Now I have to hope it doesn't rain tonight or tomorrow, and that I can get a couple hours to button it back up. I'm in it another hour going to the clutch shop to get the new clutch components, so 3 1/2 hours total. I'm dreading the reassembly process. I'm not sure how I'm going to reapproximate the halves correctly.
   / Ford 1700 clutch adjustment #53
You are certainly making good time:thumbsup: she'll be purring along before too long.:)
JC,
   / Ford 1700 clutch adjustment #54
No dread if you keep in mind what needs aligned as you close in. Main shaft through TO bearing, then shaft spline through disc, then shaft nose into pilot bushing and case dowels/holes lined up. Heavy awkward parts yet delicate alignments. Don't get mad and you'll do fine. Some experienced help is a great benefit too. Good luck, don't rush.
Jim
Thanks for the advice. Unfortunately, I'm stuck doing it entirely on my own, and in the dirt. :( We'll see how it goes, though. It's just a matter of time, tools, and effort...
Well, it's back together. What a mess! I never want to do that again, but it sure was better than paying what the mechanic would have charged! Here is my new clutch assembly. I sourced it locally for what it would have cost to buy online and ship.
I learned that it's mandatory, at least for me, to pull the steering box in order to align the components. There was no way I could do it through the sight port on the transmission case. I would have saved myself 30 minutes of struggling uselessly had I just done that to begin with. It's entirely possible that with more help, or skill, it wouldn't be necessary.
I decided it's not fair to count the time going to get these parts against the clock. I'm in almost exactly 6 hours so far. Still to be done is to replace a couple rusty and slightly bent loader mounting bolts, install the front driveshaft, and fill it up with hydraulic fluid. Hopefully by then my starter will have arrived.
To install the driveshaft, I expect to have to pull the axle assembly, unless there is a shortcut I can't figure out. Does anyone have any tips?
Also, is there a torque specification for the bolts connecting the engine bellhousing to the transmission side? I don't want them to overtighten and break anything, but don't want them too loose, either.
   / Ford 1700 clutch adjustment #57
it seems you are making good progress. :thumbsup:Axle does not to be taken off, you need to do it at the front axle sliding coupler retainer. Good and tight probably is good. They are high grade bolts, so would not be worried about twisting them.
JC,
Pics, courtesy of Russell.
I'm a little slow, I guess. I couldn't figure out how to get the drive shaft into the tractor. The tube with machined down ends fits into notches on the transmission and the axle; I don't see any way to telescope things so that they fit. What moves to allow the covering tube in?
   / Ford 1700 clutch adjustment #59
I am not sure but the couplings do not give enough travel to install the drive shaft. I removed the 4 bolts for the axle housing pivot. There are dowel pins for alignment. Anyway removed 4 bolts, jacked up frame to clear and rolled wheels FWD to clear driveshaft legnth.
Russell
   / Ford 1700 clutch adjustment #60
I have not done the work myself as I do not have font wheel assist. I did look it it some time past in the FO-44(Repair manual) that the sliding coupling in the front once removed would slide far enough to remove.
I'd follow Russell's recommendation as he's done it successfully.
JC,
(8) UNUSED 9' X 5' WROUGHT IRON SITE FENCE (A58376)
(8) UNUSED 9' X 5'...
NEW HOLLAND TC55DA TRACTOR (A58375)
NEW HOLLAND TC55DA...
KBH 25 TON TENDER (A56438)
KBH 25 TON TENDER...
2010 SHOP MADE LIMA MAC 60KW GENERATOR (A58216)
2010 SHOP MADE...
Spinning Target (A57149)
Spinning Target...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
