B2920 Alternator Upgrade
   / B2920 Alternator Upgrade #11
14 amps is the stock for all B2#20 tractors. That powers all the standard lights with just a little extra. I am considering the upgrade too, for the same reason, on the B2620. It's pretty much the same tractor with a few less HP, so it's the same kit. Supposed to have the alternator, belt, bracket, wiring harness,and the regulator. It's not an easy unplug/plug-in upgrade, but it dosen't look like you have to do any custom work to get it installed. It looks like you have to remove the dash to locate some of the parts. There looks to be a bit of time involved, so that explains the cost for the dealer to install it.
   / B2920 Alternator Upgrade #12
for $4-500 upgrade it would almost seem worth it to use a deep cycle marine battery to add-on just for those late night jobs.....just throw a charger on it when done..
I guess if no extra current draw is necessary then 14 amps is enough for just recharging ...
Having a cab with blowers, wipers and extra lights would certainly be a burden for the stock alternator
Does anyone have any numbers or pictures of the upgraded alt..??
   / B2920 Alternator Upgrade #13
14 amps seems kinda small......are ya sure that's not 14 volts..??..:confused2:
14 amps is plenty. in a DC system 55watts is 4.6 amps of draw. You don't have much draw from running the engine like you do with a gas engine. it's all lights and topping off the battery.
   / B2920 Alternator Upgrade #14
Yes, AND,,,the LED lights are like 1-2 watts each,,and brighter than the sun
   / B2920 Alternator Upgrade #15
LED lights are great but they do not produce heat. Heat can be a benefit when snow plowing to keep the light clear. Of course, it is completely wasted watts if your not getting snow on the lights.
I just got a used B2620 and I'm considering putting a LED light on the ROPS facing forward and some conventional light facing rearward for rear mounted snowblower.
   / B2920 Alternator Upgrade #18
Quote:
I'm not sure that's true - Check out the heat syncs on the backs of these LED lights:
I think you are right. I stand corrected. Here's a link and an outtake from an article I just found:
LEDs Magazine - Fact or Fiction ? LEDs don?t produce heat
Fact or Fiction LEDs don稚 produce heat
An often-quoted advantage of LEDs is that they don稚 produce heat, and are cool to the touch. Fact or fiction?
In one sense this is true: LEDs are cool to the touch because they generally don't produce heat in the form of infrared (IR) radiation (unless of course they are IR LEDs).
IR radiation heats the enclosures and surroundings of incandescent bulbs and other sources, making them hot to the touch. The absence of IR radiation allows LED fixtures to be positioned in locations where heating from conventional sources would cause a particular problem e.g. illuminating food or textiles.
However, crucially, heat is produced within the LED device itself, due to the inefficiency of the semiconductor processes that generate light. The wall-plug efficiency (optical power out divided by electrical power in) of LED packages is typically in the region of 5-40%, meaning that somewhere between 60 and 95% of the input power is lost as heat.
The energy consumed by a 100-watt GLS incandescent bulb produces around 12% heat, 83% IR and only 5% visible light. In contrast, a typical LED might produce15% visible light and 85% heat.
Especially with high-power LEDs, it is essential to remove this heat through efficient thermal management. Without good heat sinking, the internal (junction) temperature of the LED rises, and this causes the LED characteristics to change.
However, in a practical situation, when snowblowing, I think halogen lights will melt accumulated snow more than an LED because of the infrared radiation. But you can always just wipe the lens periodically especially if reachable from the seat. And as has been pointed out on tractors with limited amperage dynamo's the LEDs consume less amps.
Bottom line, I have the 14 amp dynamo, so you convinced me to go with a couple of LED's instead of halogens. Thanks.!
Just something to consider.
Thanks all, although I am still confused now. I will wait and see what it looks like when it arrives. Dynamo vs alternator, versus what it takes to drive lights. Confusing.
   / B2920 Alternator Upgrade #20
Reason I did upgrade was 2 55 watt Halogen spots in front of cab (9 amps)
3 speed heater. (10 amps)
2 55 watt floods in rear. (9 amps)
Electric wiper (4 amps)
Electric chute linear actuator (4.5 amps)
36 amps + stock lights + strobe
I obviously don't run all at once as I would still not have enough juice!
I decided to do this after I refueled tractor and it would not start!
Diesels will still run even if they don't have the electrical power as opposed to a gas engine
1995 Rinker Captiva 190 (A56438)
1995 Rinker...
Cat CB24B (A60462)
Cat CB24B (A60462)
2011 DRAGON 130BBL VAC TRAILER (A58214)
2011 DRAGON 130BBL...
2015 VOLVO L110H WHEEL LOADER (A60429)
2015 VOLVO L110H...
2022 JOHN DEERE 624P WHEEL LOADER (A52707)
2022 JOHN DEERE...
2003 International 9200I (A53317)
2003 International...
