Honda generator won't start.
   / Honda generator won't start. #1
whistlepig
Elite Member
Preble County, Ohio
Kubota B7800 with FEL
The first time I really used my four year old Honda EB6500X generator was this past February during a four day power outage. It ran about 80 hours continuously except stopping for refueling and did great. It wouldn't start today. I am a little upset because of the extra money I payed for a Honda so I wouldn't have this sort of problem. I have always drained the tank and carb after each use. Always used gas treated with Stabil. Fresh gas every year. It appears that I am not getting fuel to the plug. I think the carb is gummed up. I'm not going to fool with this. I'm going to take it back to the dealer Monday.
   / Honda generator won't start. #2
Whistlepig,
I bought a new generator this past March and went to start mine back in July and I had the same trouble....
My new generator had less than 2 hrs on it and I knew it wasn't getting any gas also....always used stabilizer in gas too
I found an old windex bottle and misted new fresh gas in the throat of the carb while tweeking on the choke to force it to purge the old gas out of the fuel bowl while it was struggling to run
it took 5 to 10 mins or so to finally clear up the old gas and since it has been fine
Back on Halloween weekend I ended up putting 58 hrs on the generator hour meter without fail during a poweroutage......
They other thing I added was a tee in the gas line with a shut-off on the drop so I could easily drain out the tank in order to change to new gas...
try the spraymist bottle and choke to see if it'll clear up before taking somewhere.......
   / Honda generator won't start. #3
..................try the spraymist bottle and choke to see if it'll clear up before taking somewhere.......
+1. I keep a primer bottle in my barn for starting stubborn engines and it saves a lot of time. Often you just need to pop off the air cleaner, give it a shot and they'll start right up. Sometimes you need to feed it a little while through the air inlet until the crud in the carburetor passes.
   / Honda generator won't start. #4
I've had the same problem with several of my small engines. I've had great luck turning the motor over with an electric drill. I've never needed more than a couple of minutes before it fires and then a little more until it will run on it's own. After starting this way a few times, they have always been able to pull start again. Mine have all had a bolt or nut on the crank that was used for this. Some easier to attach than others and make sure you are turning the right direction.
   / Honda generator won't start. #5
I used to use starting fluid and carb cleaner but realized engines over time don't like it, and they may end up ONLY starting with it over time....:confused2:
   / Honda generator won't start. #6
The only real solution to prevent carb fouling is to run the unit using some high quality ethanol free fuel designed for small engine applications before storage. The stuff is expensive and tough to find, but your small engine carbs won't foul. Even at $15/gallon it's cheaper than cleaning and replacing carbs.
SEF 94
   / Honda generator won't start. #7
I have a marine techy in the area that buys a 55 gal drum of racing gas and stabilizes it......then winterizes boat motors with it.....
He says it's the only way too.....I don't know where he buys it around here though, certainly not in any regular gas stations, race track I reckon
   / Honda generator won't start. #8
try takeing out the spark plug and dropping 2 or 3 big drops of gas in there then reinstal the plug and give it a crank, if it fires then repeat untill it continues running.
if it will not fire take the cover off (the one that has the pull cord on it) take off the spark plug wire and follow it back to the coil check for cracks on the wire and coil if there are no cracks turn the fly wheel you will see 1 or 2 smooth spots if they are rusted clean them with sand paper remove the coil and check the pickups they will probbly need to be cleaned also. Put it back together and try to start again.
Not useing these things untill you need them generally is not a good idea, best to at least once a month start up all of those little gas engines you have just to keep them going.
   / Honda generator won't start. #9
SEF 94
I run my generators every two weeks, just like it says in the owners manual. I plug two electric heaters into them to load them up and make sure they actually put out electricity. Then run for 15 minutes or so. Been doing this for 14 years. I did have to clean the carb on one once. It would not run at a stable speed.
The generator head can soak up moisture and short out if it is not warmed up occasionally.
Whistlepig,
Thanks. I might try this tomorrow. I am not real happy about this right now. My gas lawn mowers and ATV's sit most of the winter with no special treatment. No Stabil, no fresh gas, no draining of the tank, etc. and they start every spring. I baby this Honda generator with every tip that I have ever read on storage and now the darn thing won't start.
FORD 555B BACKHOE (A51246)
FORD 555B BACKHOE...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A55301)
PENDING SELLER...
16ft T/A Flatbed Equipment Trailer (A50322)
16ft T/A Flatbed...
TAKEUCHI TL12R2 SKID STEER (A52705)
TAKEUCHI TL12R2...
UNUSED RAYTREE RMH680 HYD HAMMER (A54757)
UNUSED RAYTREE...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
