Island Farmer,
I bought a 5085M just over a year ago. Best tractor I've ever owned. :thumbsup:
As far as hp requirements go, here's a pic of it with the 8-shank Hay-King renovator plow. I would have to remove a chisel (or two) if I had any less hp. (or plow much more slowly) With the 5085M, I can plow about 3-4 acres per hour.
No problem with a JD 457 round baler. (4'x5') It will run a Rhino 7' brush-hog and can work it in the 540E setting.
I didn't even consider the 75M. I wanted the higher capacity hydraulics and more hp. (I was replacing a 100hp tractor) My decision was between the 85 and the 95. What made the choice a little easier was a local dealer that had the 85 in stock, with all the options that I wanted and a price I could live with.
I really have no regrets with the 85. 10 more hp would have been nice, I guess, but not really needed. Plus, the 95 would have been about $3000 more, and would presumably burn a little more fuel.
Bigfoot62,
Thanks for your information. Your tractor sounds great. In my case, I am still struggling to make the decision between the 5075M and 5085M, here is why:
I want to balance the need for completely adequate horsepower (if I err I would like to give myself a little extra for engine longevity) with my desire to have as fuel efficient a machine as possible. Let my describe my intended use, which I believe is less challenging than yours.
I will be tilling no more than two acres, and possibly less than an acre.
Between my fields and my brother's nearby farm, I will be maintaining around 60 plus acres of pasture. Clean up mowing after rotating the cows on to the next pasture. Also, I mow along the fence line in forested areas, of both of the farms, somewhere between 5000' and 6000' feet of fence line.
Between our fields and some nearby that are available to me, I could be making hay from up to 75 acres of fields, but that would be the outer limits. Much more likely I would be making hay from between 30 and 60 acres of fields.
With the exception of tilling the garden areas, I do not plow, there are just too many rocks where I am.
After reading your post I have a couple of questions:
First, you said that you run a 7' Brush Hog pretty easily in the 540e setting. That really sounds good to me. I currently have a heavy duty Woods 6' rotary mower, which I will probably keep and then add a heavy duty flail mower no wider than 8'. It would be great to use those with the 540e setting.
AKfish, If you are reading this, any comment you might make about your tractor and its capacity to handle an 8' flail mower in 540e pto setting would be appreciated.
Second question for you Bigfoot62, you said that you didn't consider the 5075M because of its smaller hydraulic capacity -- what are you using the greater capacity of your machine for?
Thank you for your input.
Island Farmer
