First use of snowblower w/o chains
   / First use of snowblower w/o chains #1
George the Beagle
Gold Member
Southern Maine
BX 2370
Got to use the bx with front snowblower the other day for the first time. Having read the opinions about tire chains, I was waiting to see how it would work without them. My first few passes were directly out of the garage down a moderate grade, then reverse to the garage. I did notice a very slight spinning when backing up the grade, but not too bad. I finished the job with out any further spinning. Just as I was putting the tractor back in the garage I noticed....that I hadn't even had it in 4wd! The tractor has loaded turfs, a soft cab, and....er.....me in the seat. I guess I won't be needing any chains.... :D
   / First use of snowblower w/o chains #2
ice would be the real worry ...if you want cheap insurance, get a set of chains for the front...light and relatively easy to put on (easier, of course, if you had a FEL) and give you good steering on ice; you may even find you already have a set that will fit, or can find them used on CL or whatever
   / First use of snowblower w/o chains #3
The season is still very young, perhaps where you live you dont get snow drifts like we do here in Manitoba Canada at-40f that you can drive your tractor onto without breaking through. Then maybe you dont need chains. For us here in the Great White North its Really a good idea to have chains on all fours, plus a bunch of weight.
David
   / First use of snowblower w/o chains #4
You may be able to get buy without chains however I would strongly recommend them. Something always seems to happen and you end up in a situation (ditch, snowbank) that you did not expect to be in. Jacking and shoveling in the middle of a snowstorm is no fun. I run chains on all 4 tires in the winter.
   / First use of snowblower w/o chains #5
Chains don't even enter the picture until there is ICE on the ground. Then their presence is appreciated. I blew snow for years with my old tractor without any snow chains but going up hills with ice on the ground was near impossible.
   / First use of snowblower w/o chains #6
we got a b26 with a 54" blower on the back but no ice chains here just a few small hex head sheet metal screws in the r4 tire lugs made a huge difference both in the wet slick packed in ice like snow and on the ice :thumbsup:
   / First use of snowblower w/o chains #7
I bought a set of chains for my BX22 when I first got it, and have yet to use them. No grade but 0.6 mi to snowblow. It's been nearly 10 years and I have not been stuck yet.
paul
   / First use of snowblower w/o chains #8
It has only been 2 winters for me- with out chains. I normally do most of my plowing in 2 wheel drive and try to save the four wheel if I really need it. If we get a storm of 8+ inches then i use the four wheel drive for the entire plowing. The majority of my blowing is on a level asphalt driveway though. I am using turf tires too.
   / First use of snowblower w/o chains #9
My asphalt driveway goes downhill into a busy roadway. I use chains, cause I don't want to be the next fatality in my driveway(the first fatality was not due to ice).
My pickup, my car and the neighbors backhoe have all slid down my driveway in the wintertime.
   / First use of snowblower w/o chains #10
Do your tire chains damage your asphalt at all? That was one of the biggest reasons I never tried chains.:confused:
71055 (A49346)
71055 (A49346)
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A52128)
NEW 2024 LOAD...
2016 SDLG L948F WHEEL LOADER (A51242)
2016 SDLG L948F...
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
2020 KENWORTH T880 ROLL OFF (A51222)
2020 KENWORTH T880...
2013 POLARIS RANGER 800 EFI UTV (A51243)
2013 POLARIS...
