BX24 diff lock disaster ... How many others have had this problem?
   / BX24 diff lock disaster ... How many others have had this problem? #1
Carl Stevenson
Kubota BX24
Had o-ring leaking hydraulic fluid. Sent to dealer for repair. A week later, more fluid dripping out. Now they say diff lock pin sheared off inside of lower case and punched a hole in lower case. They say repair will be about $3k. Mechanic at dealer says he's done 4 of the this year (it's a small dealer).
I'm thinking this may be a design flaw (for pin failure to cause such catastrophic damage.
If you've had this problem, please contact me. I want to know how common this is.
Carl
   / BX24 diff lock disaster ... How many others have had this problem? #2
Carl,
I've had my BX24 since 2006 and have not had this problem. (I did have the common problem of shearing off the blades of the HST plastic fan, though.)
Good luck.
   / BX24 diff lock disaster ... How many others have had this problem? #3
Sorry to hear of your problem. We've had our BX for six years and over 500 hours, including plenty of dirt work, snow removal, pulling some heavy implements, all without problems to date. I will say with a tiny tractor like this, the diff lock can get a lot of use, and it's not going to be happy if it gets engaged while one wheel is spinning, so I've tried to be very careful about engaging it on the BX. I try to anticipate situations where there will be a loss of traction, for example, and engage the diff lock beforehand. And if one rear wheel does start spinning, I'll stop the tractor before engaging it. Always try to engage it going straight, not while in a turn. Don't know if that will save our BX from eventually having this problem, but so far so good. Good luck with yours.
   / BX24 diff lock disaster ... How many others have had this problem? #4
...I try to anticipate situations where there will be a loss of traction, for example, and engage the diff lock beforehand. And if one rear wheel does start spinning, I'll stop the tractor before engaging it. Always try to engage it going straight, not while in a turn...
Correct. Diff lock is low-tech traction aid...you are pushing a pin in diff carrier into hole in side gear, "locking" them together which turns diff into solid axle. If rear wheels turning at greatly different speeds, risk of breaking pin or carrier. Broken parts in transaxle can be fatal...
   / BX24 diff lock disaster ... How many others have had this problem? #5
Wow, I hope they fixed this on my bx25!
4 is a lot of failures
from a small dealer. So far so good with mine.
   / BX24 diff lock disaster ... How many others have had this problem? #6
This is what I try to do also! Can't say it ALWAYS happens though.:(
I'm not saying that diff lock pins should NEVER break. Nothing is unbreakable. My issue is with the design where, if it does break, it falls to the bottom of the case and gets pinched by the gear(s) and punches a hole in the case, resulting in a $3k repair bill!!!
Not having enough clearance to prevent that seems to me to be a design flaw. A broken pin should be able to sit in the bottom of the pan, rather than being pushed through the case, creating such extensive and expensive damage.
I would like to hear from everyone who has had this happen and investigate the possibility of getting some consideration from Kubota for the cost their design flaw has caused.
My point is that if I'm the 5th customer of one small dealer to have this issue this year (how many hundreds or thousands more across all of the dealers and all of their production?), Kubota has a problem that needs to be fixed and I think that they should make it right with those of us who have suffered from their problem.
   / BX24 diff lock disaster ... How many others have had this problem? #9
I don't see how they could fix it. Maybe install a buddy seat and provide someone to ride along and constantly remind the operator not to engage the differential lock when the machine is moving or when one of the rear wheels is rotating.
Engaging the differential lock when the machine is moving or one of the rear wheel is spinning will in all likelihood result in an expensive repairs.
   / BX24 diff lock disaster ... How many others have had this problem? #10
I haven't broken anything on my BX24 except the plastic tail lens couple times. I use the Diff lock alot, but I never used it constantly. When I get stuck, I would use the diff lock with aid of 4wd if I felt it needed it or know I only need traction on spinning rear. Its always for a moment, never more then 5 mins at a time. The only time I EVER used diff lock more then 5 mins was during a snowstorm when I had over 6 inches of really wet snow plowing and needed to punch through.
The only problem specific on the BX24 compared to other models I think is the reverse issue, maybe plastic body. Sorry to say, I dont see many diff lock failures on BX's posted here on TBN, other then not underestanding how to engage the diff lock. You never stand on the diff lever, just let it ease/slip in.
As I said above, I'm not saying the diff lock pin should never break (nothing is totally unbreakable), just that if there were a bit more clearance in the bottom of the case the pin wouldn't get punched through the case. It would still require a repair, but it would be FAR less catastrophic and expensive.
Kubota could fix this design flaw by simply allowing more space in the bottom of the case to prevent the more serious damage.
   / BX24 diff lock disaster ... How many others have had this problem? #12
I hate to defend Kubota but... Possibly the dealer is not properly explaining (as has been done already in this thread) how to use the diff lock? That would be my first reaction to 5 customers of one small dealer all having the same problem. Just my 2:2cents:
   / BX24 diff lock disaster ... How many others have had this problem? #13
I think the dealer might be blowing a little smoke here. Only maybe if the other 4 were in the same ser# group.
What do you mean "blowing a little smoke" ???
   / BX24 diff lock disaster ... How many others have had this problem? #15
Perhaps there is space for the pin to sit sideways, but the pin fell just right and got wedged sideways between the gears and the transmission case...
Aaron Z
   / BX24 diff lock disaster ... How many others have had this problem? #16
What Gator said, sorry for your issue and wish you luck but anyone can sit back and quarter back what someone else should have done after the fact.
DevilDog
   / BX24 diff lock disaster ... How many others have had this problem? #17
So they have to replace the case? it can't be welded or such?
   / BX24 diff lock disaster ... How many others have had this problem? #18
Follow instructions, do not engage differential lock with wheels spinning, now that directions have been proven that they were not followed you want the broken pieces to magically vanish and not get wedged in the gears? Go ask Cummins about the Killer Dowel Pin and see what they say about that one.
David Kb7uns
   / BX24 diff lock disaster ... How many others have had this problem? #19
By saying there was 4 others and maybe only one. If yours is the 5th, and I was the dealer I'll be calling kubota.
To the best of my knowledge, I did NOT step in the diff lock pedal with the wheels spinning. however the pin broke. All I'm saying is that if there was a bit of space in the bottom of the case, rather than a space smaller than the pin, the damage would not have been so catastrophic. To me, a somewhat minor, but predictable, failure that can't help but turn into a catastrophic failure is a design flaw.
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
SCAN TO RECEIVE TEXT UPDATES (A60429)
SCAN TO RECEIVE...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
5004 (A55851)
5004 (A55851)
20704 (A55853)
20704 (A55853)
2014 CATERPILLAR 627K SCRAPER (A60429)
2014 CATERPILLAR...
